Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: XL or "standard" tyres?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default XL or "standard" tyres?
    How do you know if your car uses XL or standard/normal load tyres?
    Let's take something like the 3.0 V6 CDTi (as it's got a heavyish engine)....
    You buy the car and it's got XL's on but you need to replace them - do you put XL's back on?
    or
    You buy the car and it's got normal load tyres on but you need to replace them - do you put standard load tyres back on?
    Where, if anywhere, does VX say you have to use XL or normal load tyres as the owners manual certainly doesn't mention it . If anybody says you "must" use XL tyres on the likes of the V6 CDTi or the GSi, I'd really like to know the reasoning behind it.
    Dec 2011
    Seaham
    You can use Ebay or places like ATS, pop in your reg number and it comes up with the recommended tryes for your car.
    You should then check the load rating stated.
    Full Member Big Sig's Avatar
    If its an Auto get the xl's if its a manual you can get away with 91w's. The auto takes them over the load rating iirc. Although I always fitted xl's to my old 3.0cdti just to be on the safe side.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    So it's a case of if the car weighs XXXX kg that determines whether you go XL or not?
    A Blackcircles search for my motor throws up standard load tyres .
    Quote Originally Posted by gtr1000 View Post
    Its down to the axle weight divided by the number of tyres on that axle as all tyres have a load rating. So depending on weight (auto's are heavier) you may or may not need xl's. There was on member on here in the past who ran the wrong load rating on his 3.0 auto after the garage fitted the wrong ones and it blew the sidewall out.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I looked online and no Vectras or Siggys needed XL tyres (although I didn't check auto's) so an Auto 3.0 Elite is the only car that MAY require them imo.
    I've never fitted them to my 2.8 V6 and not had any problems and I have been sat at speeds of 130mph with a fully loaded car at times on the autobahn (travelling to anf from the UK for Christmas with the family and dog so loads of stuff)...
    ...and touched 165mph on several occasions and my lump isn't much lighter than a 3.0
    I did some research a while ago as someone mentioned it about the tyres I was selling and XL's are more for MPV's where you could be carrying 7+ adults plus luggage. I would recommend them if you intend to transport Lead bricks around otherwise don't bother
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Defo xl tyres mate had non xl on my old Vectra c 2.0dti and the tyre Walls kept blowing out 5 in 7 weeks put xl tyres on them and they was spot on
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    VX claim a gross vehicle weight for the V6 CDTi Design of 2185kg, so dividing by four gives 546kg per tyre.
    From this table http://www.blackcircles.com/general/load-rating, I could in theory get away with a load index of 88 but 91's would be fine.
    I'm posing the question because I believe XL tyres give a much harsher and firmer ride at the expense of comfort and that the extra cost of XL tyres is not justified. Having said that, I've got Kumho KU39's (2 months old) with a 95 load index and thought that "you had to fit XL's on the V6".
    Big mistake on my part then as my previous GSi had Uniroyal Rainsports @ 91 load index and had a great ride.
    Dec 2011
    Seaham
    You cant actually divide the gross vehicle weight by 4, unless the car has an exact 50/50 weight distribution, that would also have to be factored in!
    The problem with what you have stated is that you have perfect balance over all four wheels where is reality the front axle has a bigger load in normal use than the rear due to the engine position. On the data plate on the b pillar it gives the weight per axle. Your right though, 91w's would be fine.
  1. Fitting "Standard" Radio/CD to Vectra
    By dc6839 in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2011, 19:15
  2. Standard 16" steelies with tyres
    By addyboy1982 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 25th October 2008, 12:15
  3. 17" standard vs 19" snowflakes?
    By ace in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 10:23
21555r16 vectra c max pressure
xl tyres on vectra
