Thread: rear suspension banging help
    Jan 2012
    nottingham
    Default rear suspension banging help
    hi all newbie here.
    i got a 2006 vectra club lpg/petrol
    i get a knock/ bang coming from the rear drivers side of the car when i go over a bump,
    it is only on this side and when im on a flat road it doesnt happen.
    not very mechanically minded but i always try and fix things myself to keep the cost down.
    is there any bushes that might be worn etc?
    thanks in advance
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    sounds like the upper arms are knackered, cheap enough to buy but not fund to fit, i paid a bloke £80 to fit mine, the arms cost about £40
    Jan 2012
    nottingham
    cheers mate
    will both sides need to be done as the knock is only one side?
    and will it need doing soon
    it has just had all 4 springs done for the mot and i thought the knocking noise was that but it is still there.
    Jun 2009
    South Coast
    its best to do both sides to balance the car properly.. its worth checking your ARBs (anti tool bar bushes) as well while there at it..
    Jan 2012
    nottingham
    cheers nige,
    cant believe all the springs needed doing as the cars only done 59k
    i went for a cheaper option of buying from ebay they came off a 2008 sri so they will be a little lower than my standard club springs, hope they last a little longer.
    Jun 2009
    South Coast
    lol factory springs are known to break mate, most of us replace them with something better for roughly the same price or cheaper than a dealer replacement spring set..
    Jan 2012
    nottingham
    luckily they were only £30 not sure what my mates going to charge tho for fitting them tho.
    if they go again i think ill go for lowering springs since reading a few discussions on this problem.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    my rear knocking noise turned out to be the shock itself, found out after fitting driver side upper control arm
    Jun 2009
    South Coast
    i did all my springs and shocks in an afternoon having never done them before.. a pro can do them all in a few hours or less.
  1. Banging from the rear end
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 22:15
  2. Banging from rear?
    By Dazzy2006 in forum Handling & Braking
    Last Post: 9th March 2010, 20:41
  3. Clunking/Banging From Rear Suspension
    By kevin9885 in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2009, 23:31
  4. suspension banging noise
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2008, 19:12
  5. Banging from N/S Rear
    By Fireyfella in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2007, 11:22
