Thread: water washer pump
    Sep 2010
    Default water washer pump
    My new falcon seems to have poor pressure on the washer jets compared to my old falcon,.. is the pump a simple change?
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Pretty much. You might need to have to take the bumper off to get better access but then it just pulls out of the bottle. Check the rubber filters not just gummed up before getting a new pump.
    slough
    what the hell is a falcon? if its a vectra c jack up the front left wheel remove inner wheel arch covering and you can see the pumps without taking the bumper off and you pull the pump up and out if you need to disconect the water hoses, warm with a lighter the rubber ring around the part that joins the hose to the pump, makes job much easier
    11 Post(s)
    Quote Originally Posted by hippo View Post
    No need to jack up the car, or remove the inner wheel arch lining. You can do it on the ground and only have to peel the arch lining partially back to gain access to the pump and filter.
    See the HOW2 for details
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Yup, have done this a couple of times myself to gain access to the washer pump.
    Turn the road wheels all the way to the right, couple of small torx screws to take out the plastic liner, and yer in.
  1. Water pump 1.9
    By Kramel in forum Engine & Drivetrain
    Last Post: 15th July 2012, 12:12
  2. Water pump
    By Kramel in forum Diesel Engine related
    Last Post: 19th June 2012, 13:44
  3. Water Pump????
    By Griff72 in forum Engine & Drivetrain
    Last Post: 19th August 2011, 00:36
  4. Washer Pump
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 13:29
  5. washer pump
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 15:37
