Thread: Cambelt & Water Pump
    South West
    Default Cambelt & Water Pump
    Hey all,
    Anyone give me the going rate for having a Cambelt, tensioners, idlers and Waterpump replaced on a 2.0T?
    Cars at 64000 - 6 Years Old. Probably a few more miles to go yet!
    Been reading a few posts about it, and in capable hands its a straight forward job... Is this the sort of job an independant can easily undertake, or would be be better to look for a more specialist garage if not going to VX?
    Seems the way to go is buy a full kit, then get an indy to do it.. Yes/No?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Don't know which posts you've been reading but the 2.0t has a chain not a belt
    Also, chain on a 2.0T doesn't have a replacement schedule, Should only need done if any issues are apparent.
    Sent from my HTC Desire using Tapatalk
    South West
    Doh!
    As you can probably guess, its not something that i would attempt myself!!
    So, if it does not have a belt, and the chain done if something untoward is found, what about things like the water pump?
    Basically, the cars at 64k, i am planning on keeping it for a good while yet and trying to compile a list of areas which over the next couple of years could be in line for replacement... A bit of preventative measures i guess instead of being hit with one big bill!
    Rgds
    Aidi
  1. Water pump / Cambelt / Pre-cat downpipe
    By pthres in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 23:22
  2. Just had cambelt & water pump done
    By aps in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:46
  3. 3.0 v6 cambelt/water pump
    By bigsteve3.0v6 in forum Y & Z30DT Specific
    Last Post: 11th September 2011, 23:44
  4. 3.2 v6 GSi cambelt and water pump
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2010, 20:07
  5. cost of cambelt and water pump?
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 16:15
