Results 1 to 10 of 21
Thread: 2.2 DTI Glow Plug Disaster
    Regular Member the_riddler's Avatar
    Oct 2010
    Carshalton
    Default 2.2 DTI Glow Plug Disaster
    Well what a day i have had.....
    I went to change my glowplugs this morning and two of them were a piece of cake the other two however are now snapped off in the head
    To add insult to injury i attempted to drill them out, one i had a go with a stud extractor which is now broken off inside it and the other has half a drill bit in it so this thread is quite rightly titled glow plug disaster!!!!
    Im now faced with the concept of re drilling them and having to drill into hardened steel! or removing the head and having a go from the other side!
    Any ideas would be great because i'm all out!
    Jun 2011
    Herts
    ouch. is drilling a centre hole, reverse tapping a thread and then inserting a reverse thread bolt to use as a turning tool, an option???
    Oct 2010
    Carshalton
    Oh and i cant drive it because i'm loosing compresion from the right side cylinder through the remains of the plug that has half a drill bit in it!!!
    Oct 2010
    Carshalton
    Quote Originally Posted by FLOB View Post
    i guess, i was going to try and drill out the body of the plug and also drill out the theaded part then tap a thread into the remains of the plug and then use a nut and bolt as a puller, if you get what i mean!!
    Dec 2011
    Seaham
    You will probably find the stud extractor isnt hardened steel and neither will be the broken drill bit, unless you sed a cobalt drill bit?
    Regular Member tommy1976's Avatar
    Apr 2008
    somewhere
    if you search google for sheared glowplug there are sites with instructions to get them removed.
    East Midlands
    Just a couple of quick questions?Did you try to remove the plugs from a warm or cold engine..?Did you spray the GPs before removal,mine need doing and this is the reason i keep putting the job off.
    ?Is this any good to ya.
    [ame="http://www.youtube.com/watch?v=kQ4DnWPeQpI"]Glow Plug repair//How to remove stuck glow plug (s) - YouTube[/ame]
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    U should warm the engine then spray with loads of wd40 leave to soke then remove them
    Oct 2010
    Carshalton
    Yep the engine was cold, first mistake lol i did the wd 40 thng tho and still no joy.
    Cheers for the vid but with mine its the whole plug body thats siezed in and i got a drill bit in one and ahlf an easy out in the other. I think im gonna have to start with trying to drill out the hardened steel which is going to be a mission in its self!!
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by the_riddler View Post
    The problem with drilling is if you go too far and break through all the swarf and crud will fall straight into your cylinders. If you use a small punch and keep tapping the broken drill and easy out they may eventually come loose and you will be able to pick them out. Go gently though and it depends how much access you have. Not much use now but when I did mine I sprayed them every night for a week with releasing oil before attempting to undo them - a right pain but I was a bit paranoid.
    Try a couple of local garages and ask them what they would do - they may have contact with a local mobile repairer who will come out to you.
    Alternative is to get the head off - good luck with it.
  1. 2.0 DTI Glow plug broken :(((((
    By sinless in forum Vectra C / Signum Troubleshooting
    Last Post: 18th March 2012, 10:57
  2. glow plug fault?
    By wilbur1 in forum Engine & Drivetrain
    Last Post: 10th February 2011, 19:00
  3. What a complete disaster! Glow plug FAIL
    By John LE in forum Engine & Drivetrain
    Last Post: 28th October 2010, 13:01
  4. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  5. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
signum 2.2dti glow plugs part number
