Thread: Spanner Light
    Jun 2009
    Nottingham
    Default Spanner Light
    I've got a 1.9CDTi 150bhp Signum and for the past 2-3 weeks the spanner light comes on from cold until the car has done a couple of miles and warmed a bit. There's no noticeable loss of power.
    Any ideas what it might be?
    Andy
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    poss glow plug mate
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    i had this, as said, a duff glo plug.
    only happens when the engines fully cooled down ?
    Regular Member Shogun's Avatar
    Aug 2011
    Mines doing the same, is a glow plug expensive ?
    And if I don't do it ASAP will it do any damage cos until I get some employment I can't do much unless it's cheap lol
    Sep 2011
    problem is you will need to tech2 to confirm which plug if it is that
    mine cost me £10 for the plug, but i got the testing free at work
    Jul 2010
    stourbridge
    Hang on there, tech 2?? I'm sure threre are posts on here describing how to check glowplugs with a cheap multimeter!!
    Dec 2011
    Seaham
    Check the resistance through the glow plug. With the engine switched off and the ignition off.
    Use a multimeter set to Resistance Test, or Ohms, place on probe on the end of the glow plug (where the wire is bolted into it) and the other on a good earth.
    Compare all of the readings, the duff one should be very differen to the other good ones.
    Glow plugs tend to degrade over time, as they are relatively cheap, I would recommend replacing all 4.
    Engine : 1.9 CDTi
    Check as above.
    A good plug will be below an Ohm
    Jun 2009
    Nottingham
    Thanks all....will check them out.
    Any
    11 Post(s)
    Don't faff about changing just one glowplug.
    With petrol engines people change all the spark plugs. Same should apply with diesels too.
    Change all of them - they've all done the same milaege and work, and the others will probably fail shortly too.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
