Results 1 to 10 of 21
Thread: Help air con not working
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 111000
    Default Help air con not working
    I have had my air con regassed and now been told the clutch isnt engaging.
    Is it a costly job to fix??
    Jul 2011
    Staffs
    huh?
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 111000
    The clucth on the air con compressure.
    Jul 2011
    Staffs
    Quote Originally Posted by mikey2704 View Post
    Ohhhhh
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It MAY be becasuse the outside temp is too low. It's won't activate below a temperature (which I can't remember right now)
    Isn't it a bit cold for needing air con?
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Nothing like a bit of air con for demisting your front window......
    11 Post(s)
    Quote Originally Posted by Ste View Post
    Air con is for use all year round, not just for summer. That's why so many AC systems go wrong - because they're not used in winter and the seals dry out thus letting the gas escape.
    If the AC is used in conjunction with the heater, it makes for an excellent demister.
    Cars with climate control run the AC all year round - unless you go into the settings menu and switch it off, which is pointless IMHO.
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 111000
    So do I need to replace the whole compressor or is there such a thing as a clutch repair kit??
    Where is the best place to get a new compressor or clutch for it?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    John.Robertson priced a clutch plate for his old Vec, sure it was £400!!! Cheaper picking up a secondhand compressor of ebay or a breakers yard.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, I am aware of the occasional use of AC during the winter, and also that it works as a demister (less humidity in the air = quicker drying) BUT it won't engage belowe a certain ambient temp. So maybe there is nothing wrong, and it is just too cold for it to work anyway?
    Also, running it all the time will increase fuel consumption.
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
