Thread: Cold Start
    Regular Member larrygroke's Avatar
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    Default Cold Start
    Hey everyone my car is stating to struggle starting first thing once engine is warm its fine could this be the glow plugs? starter motor sounds fine to me..
    thanks in advance
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    How long is the glow plug light on dash for?
    Do you have a multimeter?
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    a good 5 or more seconds yeah i have a multimeter....but not to hand as its in with my dads garage stuff...which he is moving house tomorrow... will be free soon though
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    bump
    Dec 2011
    Seaham
    Check your glow plugs as they degrade, can be done with a multimeter.
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    ok will do! i did/do think this is the cause! will have a look 2moro! tft "thanks for that"
    Oct 2010
    Darlington
    On the 1.9 CDTi I suspect the glow plug is inoperative until at least below 5C but if anybody knows different please correct me.
    Dec 2011
    Seaham
    If you glow plugs are dieing, try switching ignition on, let glow plug light go out, switch ignition off and on again a fw times, to try and build some extra heat into them. Then try and start.
    My old Rover was a nightmare to start even in the summer when the glow plugs weere failing.
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. cold start
    By abz123 in forum Engine & Drivetrain
    Last Post: 15th October 2012, 22:24
  3. vec b cold start
    By twaiter in forum Engine & Drivetrain
    Last Post: 27th March 2011, 14:59
  4. 2.2 dti cold start
    By tomo610 in forum Diesel Engine related
    Last Post: 2nd January 2011, 10:47
  5. Cold Start
    By T4M in forum Engine & Drivetrain
    Last Post: 10th July 2007, 20:47
