Thread: Swirl Bar fallen off
    Birmingham
    Default Swirl Bar fallen off
    Guys,
    My friend has a CDTI 150 SRI and his swirl bar has fallen off.
    He says the car is running fine, the only thing to report is a very strong smell inside the cabin (even after a new pollen filter has been fitted).
    Can I re-attach the swirl bar for him manually or is there more to it?? Alsom is this strong smell inside (almost like burning Diesel) a result of the bar fallen off?
    Thanks, G.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Im not sure mate, im sure there is a how to on this somewhere tho. Dont think it would explain the smell tho...that might be a blow/leak in the flexi pipe at the front of the exhaust system? Thats what happened with mine!
    Engine : 1.9 CDTi
    You can reattach it but normally comes off soon after again.
    If you look around the points where the bar attaches too you will see gunk.
    That is diesel fumes and soot coming out which is what the smell is.
    Nov 2010
    Elgin
    Default Swirl bar and smell.
    Quote Originally Posted by Vaux-Man-G View Post
    Guys,
    Thanks, G.
    I had the same problem with the elite model. If you take the bar out, possibly with long nosed pliers eg, and remove the 4 rubber gromits you can then superglue small tap washers (sorry, can't remember the exact size). Honestly this works but you'll need to grind down the thickness of the washers. As for the smell, it may be the breather pipe on the oil filter casing, it drips slightly onto the exhaust pipe on my motor, on my to-do list lol. Good luck.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like his inlet manifold is past saving tbh bud. I had the same oily diesel ssmell in mine which disappeared after the manifold change
    May 2006
    scotland
    I had the same smell entering the car. I sniffed with me large beek and it was coming from the area of the swirl valves. The rod was still connected. I sprayed a can of carb cleaner into the turbo housing as the car idled. Took it down the motorway for 10 mins in 3rd gear at 70mph. Result, no smell after that. I give the car at least one thrashing per week now. Result, never had the smell return. Conclusion, something was gummed up.
    West
    after a very good clean up with carb cleaner, i didn't bother attempting to re attach the bar, i bonded 1, 2, & 4 into the open position, unplugged the egr & the motor is much better for it
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    If my monifold full of gunk can car go to limp mode after turbo kick in???? cos then I sdrive and pass 3000 revs car goes to limp mode.
  1. Question from a mate(swirl bar fallen off)
    By justin32 in forum Engine & Drivetrain
    Last Post: 7th October 2011, 22:20
  2. swirl bar fallen off
    By kamar in forum Diesel Engine related
    Last Post: 22nd March 2010, 11:30
  3. Swirl flap linkage fallen off but managed to bodge it! (I hope!)
    By jrwilshire2003 in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 22:42
  4. Something fallen down under car!?
    Last Post: 29th March 2009, 19:36
  5. The Fallen, BBC2 now.
    By mark1319 in forum General Chat
    Last Post: 16th November 2008, 09:52
Swirl bar fallen off signum
