Thread: few small jobs........................
    Gloucester
    Default few small jobs........................
    cleaned egr valve, boost sensor & fitted new fuel filter yesterday
    on 1.9 cdti.........
    By eck, that makes a difference
    well happy now
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    What did you use to clean the egr and sensor? Thinking about doing mine today, how long did it take you?
    gwent
    Use carb cleaner just spray on the boost sensor do not scrub as there a small wire in it as for the egr spray and scrub it with a small tooth brush
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Boost sensor is easy like wayne said just give it a spray but don't scrub. I removed my EGR and left it soaking overnight in carb cleaner (depends how dirty it is) doing that uses a lot of carb cleaner but does get it clean or you could use petrol that cleans things well (so i've been told)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Now put some of this in your tank http://www.ebay.co.uk/itm/BG248-MAXI...item27bfdc30c6
    Aug 2010
    Derbyshire
    Quote Originally Posted by coopey View Post
    well happy now
    Did mine Friday, complete strip down of the EGR as per "how to" because the car was getting sluggish.
    Managed somehow to put it back together wrongly, the plunger and spring bit in the plastic casing. It was worse on a test drive afterwards.
    So strip down 2 revealed as mentioned above what I had done wrong. Also cleaned the boost sensor afterwards (with Gunk)
    Now what a difference, better than it's ever been. And after a 300m round M/way journey today it's doing 55mpg. Could have been better but I was enjoying the speed rather than the economy.
    Mick
    Gloucester
    right.......................
    it's been a month and................................38 mpg!!! (from a diesel!!??)
    was getting 45 mpg a year ago, that went down to 34 mpg!!!!!! hence the clean.
    wtf is going on? (I'd be better off in a petrol!!!)
    Gloucester
    anyone got any ideas?
    scottish region
    You serviced it recently
  1. 2 jobs done
    By Knight Rider in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2012, 15:58
  2. few jobs done to day..
    By Lozza in forum General Motoring Chat
    Last Post: 12th June 2012, 19:40
  3. A few jobs to do.
    By MiniVauxhall in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 22:14
  4. A few little jobs done
    By lizard in forum Styling
    Last Post: 29th August 2011, 18:15
  5. 2 jobs well done
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2009, 23:00
