Results 1 to 10 of 13
Thread: Battery light mystery! Help me please
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Battery light mystery! Help me please
    Just had the car few months with full service history, new altnerator etc well cared for ex owner, it's a vectra c facelift exclusiv estate 1.9 CDTI 150
    Battery light comes on, battery tested as nearly drained, so had it charged using trickle mode for 2 days, full battery. Put back, battery light came on 10 minutes of driving time. So garage reckons altnerator problem. I set out, removed the altnerator out myself. Took to electronic engineered who fix them, said its working perfectly, said to me next in line is starter motor, took to same man, he found very worn inside so had that repaired with new part.
    Put all back together, car starts faster this time, even runs smoother now, but battery light came on again 10 minutes later, new battery replaced, same again light comes on,
    what else do I need to look for?
    Might need tech2 to read my car, will pay for the time and fuel.
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is it a genuine alternator? The vec doesn't seem to like non genuine alts
    Have you checked cables for high resistance etc?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by Critch View Post
    How do I check the resistances? The altnerator was replaced with same denso types to partner's same car, all services been Done at dealers, do is there anything relating to cause battery light to come up apart from altnerator and starter motor?
    Thanks for replying
    Any clue to how have car computer read? Anyone willing to help me out? Thanks
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by Humourbash View Post
    Thanks for replying
    can check the volt drop across the wire, put one of the multimeter to volts and place connectors at either end of the wire to be tested.
    all i no is that a few people have had problems with non genuine alternators
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Right, auto electrics had s loik, i arrived with battery light lit on dash, he checjef altnerstor and i told him starter moter fixed working now, battery fully charged at home, he checked battery voltage, 14.03 with engine running. He turned everything on and voltage went to 13.97 he said its spot on, and said to ignore the light!
    Any ideas to look ? Could I need ti clear faults via computer and see how it goes?? I got a laptop. What eBay item do i need to do it myself and read all errors etc and clear them then drive as normal and review any new errors afterwards?
    Hope someone help me out asap :P cheers
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    just take the bulb out lol
    slough
    i think you have a diode going in the alternator, its two equalizing voltages that put the light out on the dash, when you turn on the ignition you get the light on because you have 12 volt feed to one side of the bulb and a negative to the other side completing the circut. once the engine has started the alternater is now charging and puts 12 volts to the negative side of the bulb through a diode in the alternater which puts the light out as the circut now has no negative. if that makes sense. if a diode goes t*ts up you will get feed flowing both ways and the light will come on. p.s does the light go off on the dash when the key is turned off and removed from the ignition as it should.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Light goes out when starts and comes on about 10 minutes later, when i turn off it goes away immediately
    What opcom currently on eBay should I buy?? So I can take a better reading to know why then i post here the results??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by wardy23 View Post
    Ha ha was thinking about that earlier lol
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. Engine Electrics - Warning Light Mystery
    By dae36 in forum Engine & Drivetrain
    Last Post: 19th August 2009, 10:03
  5. Replies: 9
    Last Post: 11th November 2008, 19:05
