Results 1 to 10 of 15
Thread: Not starting just clicks!
    falkirk
    Default Not starting just clicks!
    Got a 56 Sri and have a problem with starting.On several occasions when I go to start the car all I get is a few clicks,starter doesn't turn.On trying another couple of times the car then starts.It feels like a duff battery but wondered if it could be related to the immobiliser?this usually happens in the colder mornings but has happened when engine warm also.In the past when my cars have shown this clicking they have never started until charged but as this car is starting not sure what the issue is.anyone experienced this.?.
    Classic symptoms of a duff/flat battery. If it was immobiliser you'd get a padlock symbol on the dash and it probably wouldn't even let you get as far as the clicking noise. Battery needs charged/tested/replaced.
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    i doubt its immobiliser because it would turn over and not fire. sounds like battery to me, put ya headlights on and see what happens when you turn the key, if your lights go dim then its your battery if not you could have a sticky starter solenoid
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds like starter solenoid is failing to me.
    Have you got a multimeter?
    What voltage are you getting across bat? What you getting whilst its clicking?
    Regular Member themarbleman's Avatar
    sussex
    New battery time my friend
    WGAF#5
    Cold weather short journeys .. Heating on full everything switched on to the max amp drain ... Classic symptoms of a flat battery / duff cell in the battery = time for a new one
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Flat battery defo i had the same problem year before last
    falkirk
    Thought so, but car already checked by dealer,no problem!,booked back in for next week will get them to check battery as well as sorting couple other issues
    Nov 2010
    East Midlands
    Trim : design
    Starter solenoid as stated above - you would have had more problems if battery that bad ie, power steering failure,etc
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    I had the same problem a while back. Turned out I had a bad earth on my starter motor, might be worthwhile checking all the connections
  1. CDR2005 Clicks 5-10 For Seconds?
    By AdeV6 in forum Bodywork & Interior
    Last Post: 15th May 2012, 09:40
  2. Just clicks :(
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2012, 23:41
  3. 1.9CDTI Starting Problem..it just clicks once
    By Grippy in forum Engine & Drivetrain
    Last Post: 4th August 2011, 20:27
  4. dash whirr's and clicks
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 19:06
  5. Clicks on the key
    By OysterD in forum Engine & Drivetrain
    Last Post: 8th November 2007, 09:25
