Results 1 to 2 of 2
Thread: Another Heater Problem...
    Jan 2012
    Herts
    Default Another Heater Problem...
    Newbie here...
    I've read through most of the posts regarding heating problems and here's mine.
    Vectra C 1.8 SRI 52 Plate.
    What I've checked so far...
    Remove the Glvoe Box and checked the red lever. Its turning freely as I adjust the temp control.
    Under the bonnet.
    Two pipes that appear to feed into the central console are both hot.
    If I turn the temperature to cold, there is a slight change in the temperature ( it does get colder ) but on fully heat, its barely luke warm.
    Water level is fine, definitely no leaks, but I've not changed the Anti-freeze since I've had the car ( 4 years... ) so I'm not sure if I have an airlock problem, or if I need to replace the Antifreeze.
    Coincidentally this issue appeared to happen at the same time as my rear demister stopping working too, but this might be related to pulling the fuse of the window break sensors as while back as the alarm kept going off randomly until I did this
    Any guidelines or other things to check would be appreciated.
    Regular Member headscratcher's Avatar
    Jan 2012
    dover
    hello matey,
    there was a thread on here for something the same as yours a little while ago,
    the pipes are hot seems right to me, but i am fair to say no way mechanically knowledgable,
    check the relays comes to mind,especially the ones that under the glove box,
    if memory serves me right they are to the left of the heater motor,
    red and blue?,someone must know /have a better idea what the problem might be,
    check your pollen filter while you are loooking
  1. Heater problem help
    By squeeze76 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 10:35
  2. Heater problem
    By kirstylt in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2012, 20:16
  3. Heater problem, help please
    By spandy234 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2010, 17:36
  4. heater problem
    By rickeys16v in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2010, 02:34
  5. heater problem
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 00:00
