Thread: Heater fixed, warm at last :-)
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    Default Heater fixed, warm at last :-)
    Well finally have nice warm heat again with advice from Ste took the glove box out found the red lever that was supposed to move the flap to allow the hot air to come out, it was stiff so i moved it while turning the dial sparayed a bit of WD40 on it and hey presto everything working as it should again. Some pics incase anyone else has the same problem.
    Take the glove box out and you can see the red lever attached to the black resister box sxcrewed on the side of the heater by 2 x screws
    With the ignition on i gave it a little help to move.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Glad you got it sorted.
    Aug 2011
    Letchworth, Herts
    Many thanks I was dreading going to work next week as im on earlies and its damn cold at 5am, Its nice when someone knows what they are talking about and especially when it saves someone a bit of money. Thanks again :-)
    Regular Member twinxster's Avatar
    Jan 2012
    north wales
    Vehicle : vauxhall signum
    Trim : design
    Engine : 1,9 cdti 150
    Would this work the other way round? i have the same problem, but cant get cold air. When its on blue, its the same output of heat coming out as it is red.
    Aug 2011
    Letchworth, Herts
    Its worth a try the red lever should move when you turn the dial, try taking out the glove box put the ignition on and turn your dial from blue to red id the lever doesnt move then its stuck and just do what i did, youve nothing to lose and if it does work youve just saved a few quid and taking out the glove box only takes a couple of minutes you might have to take the side panel off as well like i did but only do that if the lever doesnt move as that will make it easier to get to the rest of it.
    Jan 2012
    north wales
    Trim : design
    which one of the panels? got the glovebox off. But theres like a cheap plastic cover in the way of the dial. Is it the panel with them yellow inserts for the screws?? thanks
    Aug 2011
    Letchworth, Herts
    It's the panel thats next to the centre console held on by 3 screws once the panel is off you can see the black motor that the red lever is attached to.
  1. Vectra c heater prob only blowing warm help
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd January 2011, 17:03
  2. heater blowing warm
    By keithv1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2010, 17:09
  3. Heater blower 1,2 & 3 fixed at last
    By manimal in forum Engine & Drivetrain
    Last Post: 1st December 2010, 20:36
  4. Help Heater not warm
    By v6boy in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2010, 21:04
  5. Heater only getting warm 2005 3.2lt cdx
    By leigh w in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd September 2009, 04:15
