recently i got an pionner gm4200 and i have trouble to turn it on becose it needs and remote ignition from the headunit
so i need to know where to connect these wires or is there any bypass of it
find an ignition live and use that as the remote wire so when your car is running so is the amp
Use the fag lighter mate the black wire centre pin thats an ignition live job done
can i make a direct wre from amp +12v to the ignition wire ??? and make on it an on/off power switcher
Yes u can add a switch to the reonte if you wanna turn it on and off mate easy
Not sure about that mate
If you did that, it'd be on ALL the time even when you were parked up and in bed, making you get a bat flattery Wouldn't advise. As a temp measure, i ran mine from a cig lighter plug, just to see what it sounded like. After seeing the guage of the cable to the socket, i wouldn't advise piggybacking of it.
