Thread: CD30 mp3 remote to amplifier...
    Regular Member llcoolr's Avatar
    Aug 2009
    ALGERIA
    Question CD30 mp3 remote to amplifier...
    recently i got an pionner gm4200 and i have trouble to turn it on becose it needs and remote ignition from the headunit
    so i need to know where to connect these wires or is there any bypass of it
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    find an ignition live and use that as the remote wire so when your car is running so is the amp
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Use the fag lighter mate the black wire centre pin thats an ignition live job done
    Aug 2009
    ALGERIA
    can i make a direct wre from amp +12v to the ignition wire ??? and make on it an on/off power switcher
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by paulvectrac View Post
    I took mine from the front cig socket and ran it in with the power cable from the battery
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Yes u can add a switch to the reonte if you wanna turn it on and off mate easy
    Aug 2009
    ALGERIA
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Not sure about that mate
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    If you did that, it'd be on ALL the time even when you were parked up and in bed, making you get a bat flattery Wouldn't advise. As a temp measure, i ran mine from a cig lighter plug, just to see what it sounded like. After seeing the guage of the cable to the socket, i wouldn't advise piggybacking of it.
    Aug 2009
    ALGERIA
    rolleyes
    Quote Originally Posted by BigWilko View Post
    i'll do it just for test (amp)...sur will not keep it like this...i'v just replaced battery
    question:
    is this jumper risky to the amp !!!!!???????????
  1. amplifier and fan to suboffer
    By Manuel R.B.B in forum Styling
    Last Post: 4th August 2009, 16:02
  2. Amplifier Rating
    By siz1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2008, 10:46
  3. Amplifier on oem DVD90
    By WhiteC in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 19:07
  4. sub and amplifier
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2008, 22:48
blaupunkt cd30 mp3 remote wire sample
cd30 mp3 amp remote wire
remote cable for amp for cd30 mp3 uch & uk6
cd30 mp3 remote
gm cd30 remote on
cd30 remote
blaupunkt cd30 remote cable
