Thread: Headlight level motor
    leeds
    Default Headlight level motor
    Hi Everyone,
    When I changed a headlight bulb I dived in without thinking and removed what I thought was the bulb but was actually the levelling motor. No problem I thought, it just pops back and with a quarter turn it locks in.
    When it was refitted the headlight was a mile out - pointing way too high.
    If you remove the motor the lamp drops way too low which I think seems normal. I cannot for the life of me see what I am doing wrong. Is their a special way of fitting the motor? Anyone changed these before?
    BTW its a facelift model if it makes a difference.
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    It's like a ball joint take out the headlamp and you will be able to pop it back in it happened to me on my preface Vec
    May 2008
    Tyneside
    Here's a photo of the connecting arrangement, bit fiddley to reconnect. http://i483.photobucket.com/albums/r...1/P8130352.jpg
    leeds
    Yes I see what you mean. I have tried to push it in but as you push, the headlamp swings upwards and the socket moves out of the way. I suppose I need to get behind the socket somehow to hold it while I push the motor in.
    Managed to change the bulb OK without removing the headlight as well
    May 2008
    Tyneside
    Hold the headlight unit back by holding the connector on the back, then if you get the angle right you can slide the ball in from the top or bottom of the channel. HTH
    leeds
    Thanks tridley that makes sense. I was trying to push the motor in when I can see now that it slides into a slot. Will give it a try on the car - I really cant be bothered to remove the bumper just to do this.
  1. Headlight level sensors....
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2012, 09:52
  2. Preface - A question about headlights level motor
    By superstuper in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2012, 10:16
  3. xenon self level motor problems
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 11:42
vauxhall headlight level motor
vecta c headlight with or without motor
p8130352.jpg headlight
