Thread: temperature gauge 0
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default temperature gauge 0
    guys my tm gauge keeps showing as its cold all the time, to make it move ever so slightly i have to turn the heating to cold, and then it doesnt always move much. Even if the fan speed is at 0 it doesnt make a difference. Im not loosing any water and the heat is fine when i do put it on
    Anybody any ideas?
    Glasgow
    New thermostat required.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    Quote Originally Posted by byebyeitsagsi View Post
    i was thinking that but i thought a knackered thermostat would cause the car to eithr overheat or not allow the heating to warm up, i aint got a clue tbh lol.
    Could that also b the reason why my fuel consumption is crap?
    cheers
    Glasgow
    If its seized open during cold spells it wont heat up as it will keep flowing cold coolant which is flowing through the radiator etc. Instead of closing and allowing the coolant to flow round the engine block and bypass the radiator and heat up.
    If the engine does'nt heat up and believes its cold it will over fuel hence it using more fuel.
    A new thermostat should solve the problems.
    Feb 2011
    london
    Deffo a new thermostat!! My 58 plate 150Sri Diesel has just had one fitted after identical fault!!
    Once fitted all back to normal
    Feb 2011
    london
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    cheers guys, going to purchase one on monday, are they easy to fit? on the 150's
    Engine : 1.9 CDTi
    The temp gauge doesn't start to read till 70 degrees
  1. temperature gauge
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 15:20
  2. Temperature gauge
    By ziggy1 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2012, 02:35
  3. Temperature gauge....
    By ridgers84 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2012, 19:33
  4. Temperature Gauge Help
    By Oscar Ding Ding in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2007, 21:51
  5. Temperature Gauge
    By domino in forum Engine & Drivetrain
    Last Post: 23rd July 2007, 10:39
