Results 1 to 10 of 11
Thread: Gsi oil filler neck seal
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default Gsi oil filler neck seal
    Has anyone changed the seal on the neck of the oil filler on the Gsi? I've noticed a small leak that is dripping down onto the heat shield.
    May 2011
    bispham, blackpool
    Quote Originally Posted by larrysSRI View Post
    take the whole plastic neck off and replace the cap in the hole 30 second job
    i had a scary moment at the start of the mth thought my head gasket had gone as the filler neck was all mayo inside everyone on here told me to take off the plastic pipe and it stops it
    so if yours is leaking do the same its only needed to fill it with oil without spilling it
    Nov 2009
    south wales
    If its that easy I shall do it 2m. If it still needs a seal is it easy to do?
    May 2011
    bispham, blackpool
    think the cap seals it give the cap a clean inside and see if theirs a rubber on it when i took my filler pipe off their was no rubbers on it or the engine so it must be on the cap
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I remember that mate you wouldn't listen to me lol but I told you all would be fine
    May 2011
    bispham, blackpool
    Quote Originally Posted by paulvectrac View Post
    i was listening to you it was me thinking it was worse than it was just wanted to take it to someone to get it tested in future i will listen to people on here that way i will get a good nights sleep instead of worrying about a plastic pipe
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Lmao I was like that at first then i learnt the info of here is bang on always is
    Mine was gunked up too, paniced, read the info on here. Took the pipe out, binned it and replaced the cap in the hole. Job done
    Nov 2009
    south wales
    Job done. Just gonna check over the next few days to see if it still leaks before I clean up the engine bay.
    Cheers for the tip guys
    Nov 2009
    south wales
  1. Take off your filler neck 3.2s!
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2012, 08:47
  2. GSI creamy sludge in filler neck - normal?
    By coddy2200 in forum Engine & Drivetrain
    Last Post: 24th February 2011, 13:13
  3. Fuel Nozzle stuck in the filler neck.
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2009, 09:05
  4. fuel filler neck.
    By stanian in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2007, 09:05
  5. Milky Oil filler neck and cap
    By neilgsi in forum Engine & Drivetrain
    Last Post: 19th January 2007, 14:55
