Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: Jaspas Vec GSi!!!
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    Default Jaspas Vec GSi!!!
    Well got about a years worth to catch up on sinse this section just started. good job i have diarys else where for reference.
    Here is the day i got her back....with my old mk3 astra i was breaking
    mods started immediately.....first of all richbrook harness pads
    tax disc holder
    silvertec bulbs and white sidelight bulbs
    flatblade wipers
    badgeless grill
    debadged the rear
    boot mat
    airbox mod
    had roof painted as had a big stone chip init
    then she went on the rollers
    not bad....
    painted the calipers
    tinted the windows
    went back on the rollers....bad day all round....mines the green line...stupid fueling made 198bhp at the fly in a right hot muggy unit
    full service inc... denso iridium plugs, k&n panel, gm oil and fuel filters, wurth fuel and oil flush. gm gear oil, castrol magnetec and gm pollen filter.
    bought irmscher front splitter, vxr deffuser and rear spoiler....still waiting to be painted.
    heater fan resistor pack went....not cheap!
    changed oil pressure switch as was leaking
    old...nasty
    new
    then had a spring break
    excuse to buy these off ray.....'R2XPT'
    as well as these to complement the rebuild....uprated drop links
    and poly bushes
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    fitted new suspension
    old vs new droplinks
    how she was sitting....
    still needs a little bit more i think so dropped it 2 more turns and then measured it. this is how she sits at the moment
    very happy i must say, measurements from floor to sills are..
    FL: 142MM
    FR: 142MM
    RL: 151MM
    RR: 154MM
    so will be giving the rear right a tweak tomorrow so they are even
    also a friend bought a camber guage round and they are as follows:
    FL: -0.4degrees
    FR: -1.3degrees
    RL: -2.3degrees
    RR: -3.2degrees
    so all over the place as you can see but having it fully laser aligned next weekend and then hopefully soon after corner weighted by my friend who builds kit cars.
    had a little play last weekend aswel for the set up on same stretch of road. slightly harder on the rear to counter the understeer from heavy lump up front, handles very well, no roll, was just reaching the limit of the budget tyres so need to invest in some better ones.
    also going back to the service aspects. i ran 198bhp on a very muggy day when she certainly felt abit sluggish, fortnight later i did the service and felt like a new machine, soo much better as the plugs were ditched, oil leak sludge and fury air filter. going back on the rollers in a few weeks with migweb so should be interested to see what she pulls out the bag.
    exhaust fell off last week too lol cat clamp rotted so replaced that but centre pipe hangers fell off too so is now held on by jubilee clips....good excuse to invest i think....hmmm stainless!
    and a couple of bits i picked up for a bargain!
    chrome gearstick surround
    old vs new
    fitted
    and a set of G cams which i will put on the exhaust side when i do the cambelt. anyone who doesnt know the z32se has g on inlets and j on exhaust. g's are higher lift and longer duration so should be interested to see.
    and i think we are now up to scratch...ish.....phew watch this space.!!
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    another small update, marginally missed out on a set of vxr front brakes, they sell for around 800 winning bid was 270 lol gutted! 345mm too :O:O
    today been tweaking around with the setup again. now got it all level and correct ready for laser alignment next weekend.
    also got a recall notice through yesterday aswel haha! something about handbrake could partially release so i have been told they fit a beefier spring to the mechanism....we will se.....its free of course.
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    won 2 tyres on ebay last night for a steal.
    1x bridgestone potenza
    1x goodyear eagle f1 asymmetric
    both reinforced, run flat, xtra load, blah blah, both have 7mm too easy £250 worth and all for....£55....+abit of postage im well chuffed
    Regular Member Ben_'s Avatar
    Audiville, WM
    Good write up mate....nice colour too!
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Year : 2003
    Mileage : 256,000
    Fabulous car. Great write up!
    Where did you get the service kit from? Did the K&N make a difference? Also the uprated drop links? Mine needs so much at the moment!
    Paul
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    Quote Originally Posted by GSiFan View Post
    Paul
    here there and everywhere for the service bits, vauxhall for pollen,o + f. filters and gear oil. ebay for k&n, opie oils for plugs,halfords for castrol magnetec (offer of bogof at time so got 8litres) erm what else i miss? k&n sounds alot better, especially sinse theres a few holes in the airbox. i wouldnt individually point out the air filter as a performance gain....the iridium plugs on the other hand.....lol
    can barely see the electrodes they are that small but deffinately noticed a difference. they are designed to work to full potential through higher heat ranges so hitting 6k doesnt feel like its running out of puff as easy. the service as a hole completely transformed it though felt like i gained 50bhp haha.
    again with droplinks, having fitted coilovers and poly bushes i wouldnt individually point them out but a bigger shaft and balljoint is bound to be better not only for stiffness but also wear, deffinately worth doing since they the same price as normal ones.
    33 Post(s)
    Trim : GSi
    Engine : Z32SE
    Year : 2003
    Mileage : 256,000
    Thanks, mate.
    Quote Originally Posted by Jaspa View Post
    Where did you get 'em from, though? I fitted OE-spec ones a couple of years ago and they were toast at least 6 months ago.
    I look forward to hearing about the difference the G-cams make.
    Paul
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    ok had the alignment done yesterday. rolled in toeing out like you wouldnt believe, front cambers all over place and rears nearly 3degrees....woops
    tracking wasnt an issue had it set to parallel and front cambers around 1/2 degree. had the rears set to 1.5-2 degrees because they ran out of adjustment on the bolts lol so have to keep and eye on tyre wear, if they scrub excessively on inner edge ill have to look into camber bushes for the banana arms which aint cheap.
    must say i havnt really tested it yet but when i did throw it in to a corner it felt much more tight and precise so have to test it more when the weather sorts itself out
    also had me tyres delieverd, very impressed i must say i will get pics tomorrow.
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    tyres all fitted now soo much better grippy and better braking not bad for £50ish
vectra c heko wind deflectors
vectra with wind deflectors
