Results 1 to 10 of 16
Thread: turbo upgrade
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Default turbo upgrade
    hi all if i got a Mitsubishi TD04L14T turbo to replace my standard unit would i have to get it mapped to my car z20net or would it be ok
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What is the standard turbo for your car from MHI?
    Full Member Big Sig's Avatar
    You would need a remap to make the most of it. Bit pointless without it. isn't that the turbo from a saab areo hot? I think Dez (admin) had thought about one for his old 2.0T
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    i have as standard the Garrett GT2052
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    has anyone got a pic of where the diaphragm is on the z20net turbo?
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    I think on a standard 2.0T it is possible to just switch the turbo over (will need to clarify) although the turbo will produce no additional power.
    The water and oil line are also different between the TD04 and Garret turbo, so you will need to upgrade those also.
    To gain the best from the turbo you will need to uprate the injectors and then have it mapped - I suggest you get this done at the same time.
    neo Brothers is the place to speak to.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    in short yes you would, the ecu needs to be told what its new parameters are so you can get the benefit of the bigger turbo, otherwise you will feel no real difference.
    I upgraded mine from the Garrett to a td04 and ran it until the new map arrived (one week). My td04 was even bigger and more powerful than the 14T but it still needed the new map before it knew what to do with it.
    As stated above and by me in a previous post you would need the 381cc injectors as well to go with it.. Its a shame your so far away or a few of us could help you fit it all.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Do these engines have an electric coolant run-on pump to keep coolant circulating after the engine has been switched off?
    Jun 2009
    South Coast
    not that i am aware of
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So I either assume that you let the engine idle for a while before shutdown, or the system will auto syphon the coolant around for a while after shutdown?
    Replacing the turbo with something completely different may upset this thermal syphoning effect and, if so, may reduce turbo life. Just something to be careful of when shutting down after a fast journey (eg pulling into motorway services) - always best to idle the engine for a couple ofminutes to allow the heat to dissipate from the turbo. - you really don't want to bake the oil in there.....
  1. 2.0 turbo upgrade
    By deano1 in forum Tuning
    Last Post: 8th May 2012, 16:21
  2. Turbo Upgrade 2.0t
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2009, 22:20
  3. turbo upgrade
    By spooney in forum Petrol Engine related
    Last Post: 11th March 2009, 19:01
  4. is a vxr turbo upgrade worth it
    Last Post: 10th September 2008, 17:20
  5. V6 turbo Upgrade?
    By rj.porter in forum Tuning
    Last Post: 14th February 2008, 15:53
