Results 1 to 10 of 21
Thread: My new car.....
    Regular Member ridgers84's Avatar
    Jan 2012
    Derby
    Default My new car.....
    I finally have it parked on my drive. Had the most amazing drive back from Stockport to Derby via Buxton and Ashbourne on the A515. Some great roads as those who know it will testify (and scenery!)
    Can't believe how caked in crud it is already, got stuck behind a big lorry for last ten mins of journey. :-(
    Attachment 50982
    Attachment 50983
    A couple of quick questions.... I noticed the throttle can be quite 'twitchy' almost as if it is assisted in some way, is this normal?
    Also, the car came with a new MOT. When I looked there was an advisory that said 'bulb out light on dashboard on for one of the brake lights but all of the brake lights functioning' and sure enough the 'bulb out' light is on, I've checked every light on the car and there isn't one out, does anyone know how to fix???
    Martin
    Sent from my iPhone using Tapatalk
    Blantyre
    Have you checked the lights are level at the back and its not the "lower" side lights you can see on.
    If there all level then i had the same issue and had to buy new bulb holders / as the tracks has a fault in them , was giving a false reading when everything was working fine
    Nice car BTW
    Jan 2012
    Derby
    Quote Originally Posted by spennny View Post
    Nice car BTW
    Hi spenny. Take a look at the pic of the rear lights. I've took it at eye level, they look right to me???
    Attachment 50984
    How much did the new Bulb holders cost if u don't mind me asking?
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Nice, looks like mine. Only cleaner. Is is a CDTi?
    Jan 2012
    Derby
    Quote Originally Posted by Gubmint Agent View Post
    Nope, 1.8 vvt and lovin it :-)
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Same when I got mine, I swapped both bulbs for new ones and it solved it.
    Looks smart...
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    you think thats caked in crud, you should see mine!
    looks nice
    Jan 2012
    Derby
    Quote Originally Posted by mcpitman View Post
    Looks smart...
    Which bulbs, the brake light or one pair of the rear sidelights?
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Brake lights on mine, I think it's when the resistance on the bulb drops when it's about to go pop that freaks the canbus check out (the bit that does the bulb check)
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by ridgers84 View Post
    Vec C's are drive by wire electronic throttles (no physical cable), you get used to it
