Thread: Intermittent brake light out...driving me mad!!
    Regular Member marky2027's Avatar
    Northumberland
    Default Intermittent brake light out...driving me mad!!
    About a month ago I got the "brake light out" on the dash and so changed the tail/brake light bulb. A few days later it came back on and it seems it is a problem with the bulb holder itself. When I tap the glass part of the bulb the light comes back on. I have bent the metal contacts in order to grip the bulb better but it still comes on/off. I've checked the connections and they all seem OK so I'm thinking it could be the circuit board in the bulb holder itself. Anyone had anything similar happen?
    Nov 2007
    cheshire
    yes the contacts corrode
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Had it with mine, changed bulbs several times, checked all connections, all good. Found it eventually, it turned out to be the bit where the bulb clips into where the bulb touched it, had worn the surface of the metal away in one tiny area and that's where it made contact. Soldered a new piece of metal over it and replace the bulbs and the warning's never come on since.
    Northumberland
    last night I checked the bulb holder compared to the one next to it and it looked exactly the same. Might try with some fine wire wool on the contacts to remove any corrosion (although I can't see any really). have also bent the prong up at the bottom and it still comes on. Trial and error I guess eh?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Took me weeks of trial and error to actually diagnose mine and fix the issue. I was just going to buy new light units in the end because I'd given up, then tried what I said above and it hasn't errored since.
    Northumberland
    Was it the contact on the side not the prong that contacts the bottom of the bulb then?
    Mar 2011
    Tyneside
    Same fault here,its driving me mad!
    Warning comes on and off every 5 mins, by time I pull over to see which one it is its came back on again!
    Noticed the brake light bulbs are getting hot too.
    one of the contacts looks like it has arced away too.
    Going to try building up with solder.
    Northumberland
    My alternator packed in last week and since i got my new one fitted the bulb out message has gone. Actually when I think about it the cruise control had also started switching itself off a few weeks ago and both these electrical gremlins are sorted with the new alternator.
  1. Intermittent spanner light 2.0 t
    By roverjay in forum Engine & Drivetrain
    Last Post: 13th January 2016, 08:47
  2. Brake light - driving me mad
    By Tony2412 in forum Suspension, Wheels & Brakes
    Last Post: 25th March 2012, 14:28
  3. Battery Light - Intermittent
    By tony-1977 in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2011, 21:44
  4. intermittent light fault..
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 23:58
  5. Intermittent Oil Light
    By daytona in forum Engine & Drivetrain
    Last Post: 3rd June 2010, 21:44
