Thread: mileage reset button broke
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Angry mileage reset button broke
    mileage reset button is not working, and i need to get rid of my service light on the dash, is there any whey to do this without going to stealers, disconnect battery or something, my cheap code reader is no good, any ideas chaps.
    Full Member coldo's Avatar
    Scotland
    Assuming its the pin to the migage rest bit which has broken then buy a cheap set of broken clocks off ebay and then swap the parts over... Dead easy to do (there several guides on her about taking the clocks out and dismanteling them)...
    Failing that see someone with Op-com / Vaux-Com and they can also do it for you.
    Scotland
    Or... if it's the clocks which are at fault then buy a working set of new clocks fro ebay... They are plug and play... but you will need to have one which matched the rev reange etc and the millage will be different as these are locked to the clocks witht he CProm (is that what its called..?)
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    its just the reset buttom thats broke
    Dec 2011
    Seaham
    Tried a bit of switch cleaner??
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    if i had to get new clocks with near the same mileage is it a straight plug and play, or do i have to get them tech2 or something.
    Scotland
    Quote Originally Posted by decks View Post
    As far as I am aware they are plug and play.... Someone will confirm this shortly I am sure.
    Just make sure they match the set you have (pre face lift have a tech screen on the rev counter and post ones dont etc...)
  1. ECU Mileage vs Speedo Mileage
    By Jonsey in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2011, 15:28
  2. trip reset button
    By johnsav in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2009, 00:35
  3. Just broke broke bit of my dash
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 17:15
  4. Broken Mileage Button
    By dannnyboy in forum Bodywork & Interior
    Last Post: 13th February 2009, 14:23
  5. Broken Mileage Reset?
    By SunnyDlite in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2007, 20:53
