Thread: Chrome Richbrook door pins
    Dec 2011
    Seaham
    Default Chrome Richbrook door pins
    Well the modding has started, albeit in a minor way, thanks to ChrisVectra for the bargain and quick postage. Nice one matey!
    No trouble fitting them, except I dont seem to be able to get the rear pins as far down as the fronts? I fitted the front pins with the grub screw just vivible so I could tighten the pins on, however the rear ones are about 1/2cm higher?
    I know its not much, but, I like things even. I could of course lift the front ones to match, but would prefer to lower the back ones.
    I have checked the bores in the pins are clear and that the grub screws are not fowlingthe pins. I have even tried swapping the pins around, but still the same result??
    Any thoughts or am I just being too picky??
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    The back ones do sit higher, only cure is to cut them down a little till they sit at same height. I had the same problem.
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    i have read you need to cut down the rear ones to get them to sit right.
    i may swap mine with black ones if the door cards ever need to come off
    Dec 2011
    Seaham
    I have now raised the front ones slightly, so the Vauxhall badges can be seen when the car is locked.
    Thanks, I thought I was going mad.... answers on a post card....
  1. For Sale: Richbrook door lock pins
    By chrisvectra in forum Parts for sale
    Last Post: 25th January 2012, 19:48
  2. richbrook door pins
    By dannydm1 in forum Styling
    Last Post: 23rd August 2011, 19:00
  3. Richbrook alloy door pins x 4
    By blues n twos in forum Parts for sale
    Last Post: 3rd August 2010, 20:34
  4. richbrook door pins
    By topgun in forum Styling
    Last Post: 21st August 2009, 22:28
  5. richbrook door pins
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2006, 22:30
