Thread: No hot air out of blower
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    Default No hot air out of blower
    I've got no hot air coming out of my blower just wondering if it's a relay everything works as it should apart from when you put the dial to hot it's still coming out cold and that's not a good thing when your up at 5 o'clock. Car is a 2.0 turbo facelift 55 plate Vectra I've been to that it could be a relay behind the glove box any ideas
    Dec 2011
    Seaham
    There is normally a valve or solenid that lets the hot water into the heater matrix, think you need to cjeck that first??
    Aug 2011
    Letchworth, Herts
    Where would i look for that, I have taken the glove box out and turned the dials to listen for relays, when turning the temperature dial from cold to hot i can hear a clicking noise which sounds like its coming from the heater.
    Aug 2011
    Letchworth, Herts
    No leaking water, matrix not leaking and hoses going into the matrix are hot so must be a relay or resister ?
    Aug 2011
    Letchworth, Herts
    Anyone got any ideas as just driven home and my god it was cold :-(
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you remove the glovebox and look at the passenger side of the heater assembly behind the dash (not the blower), there is a flap with a solenoid control (Maybe coloured red?)
    Anyway, this is the one that is the controller of the heat setting. Try looking at it and turn the dial from max to min and it should move... Inside the assembly is a flap which controls the air flow.
    If you need to remove the solenoid then remove the lower inboard kick panel and also the airducting for the passenger footwell and you can get at the screws that hold the solenoid on.
    Mine stopped working the other week. I dismantled the solenoid and tried it with the motor hanging out and it worked. I moved the grease around a bit and put it back together and voila - it worked again. It's worked ever since, so I'm not really sure what the actual problem was....
    Aug 2011
    Letchworth, Herts
    I have taken the glove box out and can see a red plastic dial thing that looks like it should have a cable attached but obviously doesnt as its not cable fed is this the thing to get to it it looks like i hace to take the centre console out is that right. I have turnes the dial and the red part does not move so i guess it is stuck. My fan speed and direction dial work fine its just the cold to hot centre dial that isnt working it will turn from hot to cold but i am only getting cold air out.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Under the red plastic arm is the solenoid and should be connected by a rod to the arm.
    Aug 2011
    Letchworth, Herts
    Cool nice 1 im gonna have a good look at it tomorrow. Many thanks
    Aug 2011
    Letchworth, Herts
    Quote Originally Posted by dannycturbo View Post
    If I get it going I will take some pics and. Post them up with a how too :-)
  1. Blower
    By nokiaman1978 in forum Bodywork & Interior
    Last Post: 23rd April 2012, 22:43
  2. Need help with blower/fan
    By coogar in forum Bodywork & Interior
    Last Post: 31st January 2012, 16:52
  3. Blower gsi 3.2
    By grabcol01 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2011, 21:55
  4. blower
    By bakery in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 15:18
  5. Not hot air thru the blower!
    By jimmytarnat in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2009, 19:15
