Thread: Loosing coolant & foaming
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Loosing coolant & foaming
    Hope someone can help - after 3 years I'm at the end of my tether with my Vec DTI!
    Last Friday after an hour and a half of motorway driving my low coolant light came on - so I stopped and topped it up with antifreeze (luckily had a bottle in the boot). Since then it's loosing half a tanks worth every time I go to or from work (an hours drive). I believe the cap to be dead as it never hisses when I remove it (even when hot) and takes a while get it to screw on properly. As my tank is filthy I bought and fitted a new tank and cap on Wednesday, and thought all was fine.
    But this morning the level has dropped AGAIN and now it has a layer of foam in there too! Any ideas what that's all about? I did run it with the cap off and got it up to temp, then cooled and topped up again when I changed the tank, but I suspect something more suspicious is going on, but no idea what!
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Edit; Oh just re reading your post and you've already changed the tank.
    Apr 2009
    Stevenage, Herts
    No worries - should have added there's no obvious leaks apart from the steering rack under the tank was originally damp with coolant, so even then not a proper drip from anywhere.
    wirral
    58 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Need to get it pressure tested and check for leaks. Also get sniff test done
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Critch View Post
    Yeah ie throw more money at it I'll probably get the issue diagnosed then decide to keep or trade in
    Glasgow
    To be honest it does'nt sound to good if its loosing a lot and foaming. If it was just a burst hose or something it would'nt foam.
    I see you mentioned you changed the header tank and cap and the tank was filthy. If it was oily i think your head gasket is blown.
    Dec 2011
    Seaham
    I agree with above, dirty over flow tank would normally be caused by oil and hence a blown head gasket.
    Do you also have mayonaise under your oil filler cap?
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Ben50n View Post
    Just checked - completely clean in there.
    Dec 2011
    Seaham
    Think you need to get it pressure tested now, unless you can see any obvious leaks?
  1. 2.8 Veccy loosing coolant!
    By the_rocker in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 14:17
  2. Loosing Coolant
    By Coupe2T in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 10:03
  3. loosing engine coolant
    By pud wayman in forum Engine & Drivetrain
    Last Post: 25th March 2012, 10:16
  4. Loosing coolant on my 3.0DTi
    By Maurice in forum Engine & Drivetrain
    Last Post: 16th September 2010, 22:06
  5. loosing coolant oh oh
    By toast in forum Engine & Drivetrain
    Last Post: 21st June 2010, 22:03
