Thread: Problems with Spanner and Safe-mode
    Regular Member RichieG's Avatar
    Dec 2011
    Durham
    Default Problems with Spanner and Safe-mode
    I have a 2.0 DTi.
    When driving on the A1 recently I noticed that when driving at around 70mph for a constant period of time the car with spanner light comes in and I feel the power kind of drop for around 30 seconds or so then the light goes off and the power is restored, it will constantly do this for the rest of the drive until I have pulled off the A1 then it wont happen again. I have tried with both the cruise control on and off no difference.
    I should point out that when I drive home I do not have this issue and there are alot of national speed limit roads one in paticular I drive constant at around 65 to 70mph and I have no problems.
    Things I have done so far, I have checked all pipes and are all great, also removed EGR valve and inlet manifold and have cleaned these however this has not made a difference, any ideas?
    Cheers in advance.
    Regular Member Innes's Avatar
    Plymouth
    Get the codes read first and post up the results. My guess us it'll come up with boost pressure negative deviation. Try cleaning the boost sensor and if that doesn't work then try adjusting the turbo actuator rod my a turn.
    exeter
    how do you adjust the turbo actuator rod ? . and would it help with mpg . because my dti it only doing 40mpg and thats with me driving like a old fart ( not taking it above 2000 revs ). i have already done the fuel /air and oil filters oil changed cleaned the boost sensor egr and both upper and lower manifolds . plus changed all the vacuum hoses
    Dec 2011
    Durham
    cheers for that... il get it checked when i get some cash
  1. safe mode help!!!
    By russfred1 in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2013, 19:01
  2. Spanner and Safe Mode.
    By RichieG in forum Vectra C / Signum Troubleshooting
    Last Post: 10th March 2012, 13:41
  3. Display in safe mode
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2011, 07:33
  4. Safe mode
    By tomo610 in forum Diesel Engine related
    Last Post: 25th September 2010, 18:00
  5. safe mode
    By magpie27 in forum Engine & Drivetrain
    Last Post: 17th March 2009, 13:42
driving in spanner mode
