Thread: power steering help please
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    Default power steering help please
    i have replaced the power steering pump on my car but the new on doe's not have a low level sensor so the light is on in the dash does anyone know how to turn it off useing a diagnostic tool that i am not allowed to mention on here you know the one o*-**m any help would be greatful thanks
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is their on option on the ephs? a think it is?
    Can't totally think of top of my head, can go plug it in and try if needs be.
    Somewhere will be programming. And then click on the sensor an not present
    I think.
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    I think.
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    will give it ago tomorrow and keep you posted only want it off so it sells better
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    tried this and there does not seem to be the option to turn it off
    Dec 2011
    Seaham
    How does the swirch work? If it shorts across when the level is low or maybe opens when level islow, you could either short it across or cut the wires and leave them insulated?
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    the level float wires plug into the pump so the are no wires to short as the new pump doe's not have a level float when i plug my diagnostic into it and go to ephs and programming there is no option of a sensor and when i program the pump it says programed susscessful if i exit then go back it has gone again all i want is the light off can not even pull the bulb out
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
