Thread: 1.9 CDTI 150 Smoke when accelerating
    Regular Member 150_SRI's Avatar
    Sep 2010
    Lincs
    Default 1.9 CDTI 150 Smoke when accelerating
    Hi all,
    I have a 2008 vectra 1.9 CDTI SRI 6speed 150. This has been chipped by Bluefin.
    When i startup the car is fine, so no smoke or anything, But when im driving when its warm, and accelerate hard, so the turbo kicks in, the exhaust shoots out a load of smoke/soot.
    Any ideas why it chugs out so much smoke when accelerating?
    It only has 50k miles.
    Ive heard it might be something to do with a DGR Filter or something similar to that name that can get clogged up with Soot, but vauxhall are quoting £85 to investigate. would this be the issue?
    thanks,
    Sep 2010
    chipped or remapped ones do,.. my old 08 does and that's been re-mapped. More beoause it doesn't have a DPF (diesel particulate filter) and when gassing it, because more fuel is going in,.. more gets chucked out the back
    Regular Member bigdave1701's Avatar
    York
    IMO, Smoking when you put the boot in is just because its a diesel, it's what they do.
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Yep, as Big Dave has said, booting a diesel gives smoke. I quite like it!
    Nov 2011
    Swindon
    I believe the saying is "No smoke; no poke"
    West
    Do not rule out a boost leak, get someone to hold the revs down on boost while you have a good look around for any splits in the pipework & or intercooler.
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Mine does its great haha
    Aug 2010
    Derbyshire
    Quote Originally Posted by chewy71 View Post
    I had a chipped Omega diesel prior to the Signum and that did the same when booting it. You should have seen it when towing my caravan up a slight incline, smoke bellowing from the rear. Didn't half shift though. I removed the chip in the end, less fun, but no smoke.
    Mick
    Sep 2010
    Lincs
    had the system read with tech 2 AND THERE are no error codes so must just b as it has a lot more power now due to the Bluefin re-map :-)
    West
    Not all remaps are smokey... plus tech 2 or any other diagnostics won't show a boost leak.
    As i said earlier, check all the boost pipes / intercooler for any leaks
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. How much should a 3.0 V6 CDTi smoke?
    By neverton in forum Engine & Drivetrain
    Last Post: 9th March 2010, 23:44
  3. smoking when accelerating 1.9 CDTI (120)
    By rec in forum Engine & Drivetrain
    Last Post: 1st February 2010, 20:39
  4. Black Smoke When Accelerating
    By taximan2009 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th February 2009, 17:50
vectra black smoke when accelerating
astra 1.9 cdti black smoke
astra 1.9 cdti sri smoke exhaust
vauxhall 1.9 cdti smoking
astra 1.9cdti 150 black smoke on take off
https:www.vectra-c.comforumshowthread.php154957-1-9-CDTI-150-Smoke-when-acceleratingpage2
z19dth dpf smoke when floored
vectra cdti smokey exhaustvectra cdti smokingzafira 1.9 cdti smokingastra 1.9cdti white smoke is vectra c cdti fast accelerationwhite smoke on acceleration vauxhall vectra dieselastra cdti 150 white smokevauxhall astra 1.9 cdti smoke on accelerationvauxhall 1.9cdti 150 white smokeastra 1.9 cdti smokevectra c 1.9cdti 150 white smoke under accelerationcdti sri smoke under loadvivaro 1.9 cdti black smoke when accelerating1.9 cdti smokingwhy is my 1.9 cdti smokingvauxhall zafira smokes when accelerationopel astra smokes by acelerationvectra c black smoke acceleration
