Results 1 to 10 of 27
Thread: Had handbrake done today now got a bill of £1900 to fix everything thats wrong with my car lol
    Mar 2011
    South Normanton, Debryshire
    Default Had handbrake done today now got a bill of £1900 to fix everything thats wrong with my car lol
    Hi,
    Been had my recall done for my handbrake which it does feel alot better so glad i had it done.
    Now got a list of jobs that vauxhall want me to have done to my car for £1900
    so here goes.
    Wipers
    Drivers door check strap loose requires bolt removing loctite applying then retighten. sounds easy
    Exhaust heat shield insecure which i know about.
    Excessive play in both rear banana suspension arms.
    Nearside rear coil spring broken which im guessing this is the right part for http://www.ebay.co.uk/itm/OPEL-C-VEC...item45ff6f65a5
    Offside front coil spring incomplete which again im guessing this is the right part http://www.ebay.co.uk/itm/VAUXHALL-V...item1c0d7e9f14
    Play in nearside front steering arm ADVISE
    offside front lower control arm bush has slight damage ADVISE
    then brake pipes corroded which i know about.
    Can anyone help me with any of the other parts as i dont know what im looking for.
    Cheers Alan.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    You could do all of that yourself if you know someone with some mechanical experience? All the suspension components would still come in at under £500 even upgrading to Eibachs.
    Then say another ton for the extra parts. You could even get new shocks all round and still be about half the price Vauxhall have quoted you...
    Mar 2011
    Yeah i know i can get it a lot cheaper plus my friend is a mechanic so he'll probs do the work for free or very little anyway thats why i wanted someone to point me in the right direction of the parts so i can prder them for him really.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    How the heck can that lot tot up to £1900.... that's steep even for a VX dealer !!
    What is wrong with the wipers?
    Mar 2011
    Basically the wipers want replacing coz there smearing the windows
    Heres all the prices they have given me.
    3 wipers smearing screen £11.40
    Wiper £10.14
    Rear Wiper £9.78
    Drivers door check £34.80
    Exhaust heat shield £87
    Excessive play in both rear banana suspension arms £324.30
    Nearside rear coil spring broken £306.90
    Offside fron coil spring incomplete £340.50
    Play in nearside front steering arm ... ADVISE £258.72
    Offside front lower control arm bush has slight damage...ADIVSE £179.40
    Bolts £4.42
    Bolts £3.65
    Front brake discs inner face badly corroded pads approx 20% worn 104.40
    Front to rear brake pipes corroded £217.50
    Total £1918.99
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    lol. You sure it was Vx and not Kwik Fit?
    Glasgow
    Quote Originally Posted by Alank View Post
    Hi,
    so here goes.
    Wipers Change the blades yourself.
    Drivers door check strap loose requires bolt removing loctite applying then retighten. sounds easy Do that if its bothering you.
    Exhaust heat shield insecure which i know about. Remove the old nuts and put nice big washer on with new nuts and it will be secure again.
    Excessive play in both rear banana suspension arms. Get them both checked.
    Play in nearside front steering arm ADVISE IGNORE
    offside front lower control arm bush has slight damage ADVISE IGNORE
    then brake pipes corroded which i know about. Ignore or give them a scrub with a wire brush it will just be surface rust.
    Cheers Alan.
    My replies are in red but i would change all 4 springs for something like eibachs. Its good practise to change springs in pairs and you have one bust on each axle so its worthwhile changing them all.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Alan, call LMFVauxhall for the springs and shocks, ask him for prices on the other parts or get somebody local to you with a vx trade card to see what they can get them for.
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    do the wipers yourself, ignore the non urgent stuff and as above shop around for prices on the urgent stuff.
    mine is in the dealers atm so i expect a big list of stuff that doesnt need doing also!
    Dec 2011
    Seaham
    Does the car have an MOT, because I would only concentrate on the MOT items first, then slowly work around the other items.
  1. Slight Droning Noise at 1800/1900 RPM
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2013, 12:36
  2. 2.2 cam chain bill today....
    By signum driver in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 19:12
  3. 2005 Vectra 1900 CDTi 150 Injector Leaking
    By MXB74 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 23:17
  4. Wrong place wrong time.
    By silverhairedracer in forum General Chat
    Last Post: 29th October 2008, 14:20
