Results 1 to 10 of 22
Thread: HID conversion "front bumper removal"
    Regular Member kevinmc's Avatar
    Jan 2012
    Ireland
    Eek HID conversion "front bumper removal"
    Just before I buy the conversion kit for Vectra C 04, why do you have to remove the front bumper, or is there another way round this.
    I have never done this before!!
    Full Member paul.sessions's Avatar
    leighton buzzard
    its easier to take the headllights out and the third bolt holding them in is behind the bumper.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Jan 2012
    Ireland
    Thanks Paul!!
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I've mounted my ballasts behind the headlights thus not removing the bumper, but i'm going to mount them under the headlights as per the How2 guide as it took me flippin ages to replace my sidelight bulbs the other week with the ballasts in the way.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I didnt have to take the headlights out or take the bumper off, isnt that just for the facelift. Taking the airbox out makes it easier but even my sausage fingers managed to get in there no probs.
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    If you want to mount them under the headlight then you gotta remove the front bumper, its easy enough to do but if you have any problems with ur ballasts it gets quite annoying removing the front bumper everytime, in the end i just mounted mine were they could be accessed easily, Worth bearing in mind
    Jan 2012
    Ireland
    cheers lads for the info..
    Full Member Big Sig's Avatar
    The bumper is only held on with a few clips and comes off in about 10 minutes if you know what to do. Its very simple, just looks worse than it is.
    11 Post(s)
    I made a tool for removing the bumper clips from a piece of meccano. Where the holes are, I just cut in from one end of the meccano so the hole was then open so I could slip it under the mushroom head to ease it out. Also bent it at an angle so I could use it as a lever.
    Made life a lot easier removing them, then I applied a thin layer of silicone grease on the stems to make it even easier next time I might have to remove them.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. Interior door sills and "b" pillar removal
    By si_hoss in forum Bodywork & Interior
    Last Post: 12th May 2011, 12:25
  3. Front Drop Links changed on the "B" and.....
    By Vaux-Man-G in forum General Chat
    Last Post: 6th April 2010, 09:31
  4. V6 CDTI gearbox removal: "A right *******!"
    By diesel dog in forum Engine & Drivetrain
    Last Post: 9th January 2009, 01:27
  5. "Grating / Rubbing" noise from front end
    By stripey in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2007, 17:05
How to remove front bumper vaux vectra c
