Thread: 1.9 cdti sri 150 like a bag of spanners!
    Regular Member craig-s's Avatar
    Jan 2012
    Livingston
    Default 1.9 cdti sri 150 like a bag of spanners!
    Hi all, just purchased a 55 plate 1.9 cdti 150 and all was well for say 10 hours.... Started it from cold this morning and it ran really rough. Lots of funny smelling white smoke from start (calmed down a bit when up to temp) Also on the manifold the swirl pots have a bar thing on them? this is loose to the point it falls off. looking at it from the bumper to the windscreen the 3rd and 4th pots are really dirty/oily. is there a way to reattatch this bar. What sort of damage will this cause if its loose? I've got a 200 mile drive on friday that i'm more than wary of taking! mpg was good and temp was fine but pulling away was pretty juddery. any advice would be greatly appreciated!!! thanks craig
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have a look what I did to mine.
    http://www.vectra-c.com/forum/showthread.php?t=142503
    It's still running great now, with the swirl pots glued open
    Dec 2011
    Seaham
    If you have just purchased from a garage, take it back for repair!
    Jan 2012
    Livingston
    wish I could but it was a private sale. Cant complain too much as it was a bargain, even with the possibility of a new manifold. cheers tony, thats really intresting. I will do that tomorrow to see, planned on a new manifold but i'm all for trying ingenious little fixes!!! nice one
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by craig-s View Post
    No probs mate. Keep us posted
    My motor has 134k miles on it, with the original manifold. The next cambelt change will be at about 165k miles, so might consider a new manifold then, but if it still runs as sweet as it does now, it'll stay put!!
    Jan 2012
    Livingston
    mines got 50k on it. Did not expect to replace a manifold this early! will try the fix and if needs be glue the pots in place. Will keep you posted!
    Dec 2011
    Oxford
    I will be changing mine shortly as well .... but for now
    What I did to mine is to do a small fix and put it on again.
    - Buy some plastic/rubber seals matching size (i think 3mm or 4mm).
    - Remove exact high as washers you planning to glue in (due to no space above this bar) from black plastic ends on this bar.
    - Effectively you make it shorter at this time.
    - Glue in washers and put it back in. It did required a big push due to plastic washers I used, but when they click and lock in was great.
    It drops again, but only from third one. They tend to open a bit when not blocked by 3rd (possibly some pressure makes it happen) and they will always close when 3rd closes.
    Driving like this last 5k miles. No issues, no power loss.
    Worth trying as temporary solution.
    Remember to use high temp glue.
    Jan 2012
    Livingston
    had a good look today, the number 2 and 4 look like they are blowing out and rattling all over the place. The exhaust gases smell terrible! is this related? Anyways, looks like i'll be doing the metal bonding fix for now and see how that goes. 185 for a new manifold is pretty decent so worse case scenario I will change it over a weekend. Driving it up the highlands tomorrow so hope it makes it! whats the worse that could happen...........
  1. got the spanners out
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2011, 20:03
  2. Bag of spanners
    By mab66 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st August 2011, 15:59
  3. Ratchet spanners
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 21:11
  4. Bag of Spanners
    By 123yka in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 21:21
  5. how many spanners are you....?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2008, 21:12
