Thread: Can Bus
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Default Can Bus
    Hi all, stupid question time (again).
    What is a can bus connection? what does it do? and do I have to do anything different when changing bulbs / stereo / etc.
    Cheers all
    Tony
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Can Bus is a system that send's pulses of voltage/information...
    only thing different is that you have to fit cancelers if fitting led's or hid's, a quadlock is needed for stereo swap over and on full canbus car's the security code runs through the stereo and screen and they have to be divorced from the car before thay can be used oin a different one
    hth
    Midlands Mod Shop - NFFC.
    11 Post(s)
    Google, among other search engines is your friend.
    [ame="http://en.wikipedia.org/wiki/CAN_bus"]CAN bus - Wikipedia, the free encyclopedia[/ame]
    http://www.canbuskit.com/what.php
    http://www.bba-reman.com/content.asp...otive_industry
    South east
    CANbus is a network of electronic control units (ECUs). Some years ago cars had just one ECU, and it controlled just the engine. Nowadays most cars have a network of them, covering many other components, such as the lights, stereo, steering, etc etc. This allows the system to be very "clever" and monitor many functions of the car, making it harder for Joe Bloggs to put his screwdriver to work and make willy-nilly changes to components.
    Slough
    92 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by Tinks View Post
    Cheers all
    Tony
    good Tony
    see you have got the car
    the vectra has gone , but not far away so ill still see it form time to time
    Jan 2012
    Stavanger, Norway
    When i try to access the cars ECUs with the OP-Com odb2 tool it asks me for a pin/code. It applys to the ECUs that has anything to do with the immobiliser...
    Where do i find this code/pin?
    .08 Opel Vectra C Caravan...
    Feb 2011
    Selby
    The main reason for canbus is the sheer amount of wiring you'd need to interconnect all of the different computer units on a modern car. Canbus reduces this down to just a couple of wires, as it's in effect the same as a computer network.
    It enables more functionality too, as now all the different units can look for information that might be useful to them on the bus. So little things like the rain sensor for the wipers, the door lock state and alarm state can be monitored by the electric window control unit - closing the windows if it rains and the car is left locked and unattended. Without canbus that'd take a fair bit of wiring which takes up room, is prone to connections failing and it heavy.
    The issue it can have with non-standard lights is that the lighting control unit does more that just supply power to bulbs. It can test for a blown bulb and it pulses the power supply in order to make the bulbs last longer and take less power. This is fine for the bulbs that GM designed it to use, but if you fit LEDs or HIDs they can behave oddly.
