Thread: Is there a plumber/gas man here?
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    confused Is there a plumber/gas man here?
    i am having problems with this can someone help
    baxi 80 eco?
    when on hot water and no taps running the boiler fires up for 10 seconds and shuts off and does this constantly. i have changed the stat and diverter valve and still the same. any ideas? please help
    Dec 2011
    Seaham
    Do you have a water leak on the domestic side? I am assuming that it is a combi type boiler with no storage tank.
    It will be reading that there is a drop in pressure, and think that a tap has been turned on, hence busting into life until the pressure builds up again?
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    theres no leak this has done my head in all day. been out twice to this job. no pay till sorted
    Regular Member jsnlvxr's Avatar
    wiltshire
    maybe the dhw flow switch is flow switch is faulty and jammed open causing it fire up get up to temp and shut down. if you look inside the boiler its the micro switch on the front of the diverter valve.get someone to open and close a hot tap and you should see a pin moving in and out which makes the micro switch.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    the micro switch works fine. on the diverter valve the pin in the top stick out when boiler is switched on and doesnt move but make the micro switch
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    I will ask my Hvac engineer at work for you if not solved by monday, but of top of my head can only think its either overheat thermostat, Temperature sensor or the diverter valve. Could be the hot water microswitch is stuck so the boiler thinks there is demand for hot water. I only use to install and service central heating buddy so thats as far as my knowledge will help ya....
    But as said I will ask the hvac guy at work Monday as he is in to service our water heaters and aircon.
    Hope you get it sorted buddy.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    cheers matey
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Well it turned out to be the DHW microswitch. Easy fix at last
  1. Anyone know a good reliable plumber?
    By wingz123 in forum General Chat
    Last Post: 22nd May 2011, 19:16
  2. Anyone a plumber ???????????
    By Signumcdti in forum General Chat
    Last Post: 26th April 2010, 21:49
  3. any plumber merchants out there
    By kevin hunter in forum General Chat
    Last Post: 10th December 2008, 16:00
  4. gas fitter/plumber in birmingham?
    By Nickzx6r in forum General Chat
    Last Post: 3rd May 2008, 14:29
  5. Plumber needed?
    By blr123 in forum General Chat
    Last Post: 21st March 2006, 19:49
