Thread: Newbie
    Jan 2012
    Aberdeenshire
    Default Newbie
    Hi all, just joined from Oldmeldrum, Aberdeenshire.
    Just swapped my Astra van for a Vectra C 2.2Sri petrol, came with a few problems, dash/instrument failure, drivers window innop, key fob buttons on their last legs, slight exhaust leak from behind the cat, require major clean/small valet, passenger head rest missing, requires rear disc and pads
    Best to say now that I'm in no ways near to be mechanically minded, what I do know is possibly just common sense things and trial and error.
    So, eBay it was, ordered - key fob kit, headrest, Opcom fault code scanner, head unit adapter, rear discs and pads.
    Engine bay was given a good clean, maybe too much as when I went to run it again it was only running on three cylinders, did the usual disconnect what I could and made sure all was dry, still same, removed plugs, all but one were fairly low and discoloured, so ask the wife to nip into halfords on way home, plugs replaced, still the same, after looking thru this forum, I decided it could well be the coil pack, so trip to local salvage yard and purchased second hand coil pack, now running as it should with exception to this electrical issue that I believe will be the CIM module, just my luck.....
    Waiting to see if I can get the security code before I try to rest the ECU using the Opcom scanner, hopefully this will resolve the electrical issue.
    inspected the drivers window, which the regulator is all bent and window being held up with what I believe to be a table leg, eBay for menu regulator me thinks.
    Gave the inside a good clean today and looks as though the dash has been removed at some point(possibly a taxi at some point) this brings me to thinks the instrumental issue I have could(fingers crossed) be a loose connection somewhere.
    Anyways, enough from me, away to look for a window regulator
    Dec 2011
    Seaham
    Welcome to the forum, keep us updated on your progress and feel free to ask any questions.
    Regular Member kevinmc's Avatar
    Jan 2012
    Ireland
    Welcome Masson!! enjoy
    Regular Member larrygroke's Avatar
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    Welcome! Enjoy
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    welcome / hello
    Regular Member badback's Avatar
    Runcorn
    Hello and
    Regular Member nicj's Avatar
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Helloooo and welcome
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Welcome to the forum matey
    Regular Member Ralphwells1967's Avatar
    dartford
    2 Thread(s)
    Hello and to vec c m8
  1. newbie asking newbie question :-)
    By gavatron in forum Engine & Drivetrain
    Last Post: 6th February 2012, 10:39
  2. Newbie
    By bigjjfaetheyy in forum Introduce yourself.
    Last Post: 2nd October 2009, 08:57
  3. Newbie.
    By Martinlw in forum Introduce yourself.
    Last Post: 1st October 2009, 05:46
  4. Newbie
    By VectraAlan1888 in forum Introduce yourself.
    Last Post: 16th September 2009, 19:02
  5. newbie.
    By signum@37 in forum Introduce yourself.
    Last Post: 3rd August 2009, 12:25
