Results 1 to 10 of 11
Thread: Vectra GSI 2004 Major Drama
    New Member nickgibo's Avatar
    Jan 2012
    Midlands
    Default Vectra GSI 2004 Major Drama
    Hi, i am currently having major dramas with the motor and i will give a breakdown of the events below, any advice would be much appreciated.
    Day 1. Went to start and it turned over then just started clicking and the dash went haywire, lights flashing etc.
    Day 2. Tried a booster to try and jump it and all it did was make the speakers crackle to the sound system and the dash was flashing etc.
    I then jumped it with leads and it started fine, BUT when i turned the car of after leaving it running and removed the key all of the windows opened? The car would start fine but the windows just kept opening.
    I also had Check safeguard on the centre screen.
    I then removed all of the fuses to the electric windows because of the rain, again the car still started fine.
    Around 4 hours later i went to try and start the car again and it was as if the battery was disconnected, no power what so ever, so i connected jump leads again and it turned over for a short while and then i got the padlock sign on the display below the rev counter.
    I have disconnected the battery and that has cleared the safeguard but the padlock stays, i have done the pedal trick and it is showing the cim fault p1616 i think, i will confirm that.
    I am just at a loss,
    The car is totally standard, no mods what so ever and has never missed a beat.
    Any advice would be really great, thanks.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Your battery is goosed mate or the alternator because the volts drop so low the systems around the car top talking to each other mnes had both recently and even the autowiper sensor stopped talking to the REC it does many a strange thing low voltage
    Jan 2012
    Midlands
    If it happens to be just the battery will it clear all the faults?
    Cheers for the advice.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Did with mine when the volts are up to normal, unless you clear them with Tech 2 they will show for about 25 or so starts but the symptoms will go if the battery is dead and you fit a new one, simple thing is battery off and then charge it and see if it holds charge, but cold weather kills batteries that are weak
    Jan 2012
    Midlands
    I have been quoted around 80 inc from vauxhall for a new battery, i will try that fingers crossed.
    Once again thanks for the advice, i will update once i have fitted the battery.
    Is it easy enough to sell cars on here?
    Glasgow
    Change the battery, worst case scenario is the alternator. You need to be a full member to sell things, think that's £15.
    Jan 2012
    Midlands
    Quick U[date,
    The fact i removed all of the electric window fuses caused the padlock CIM fault, new battery today so hopefully half way there.
    Jan 2012
    Midlands
    Quick U[date,
    Dec 2011
    Seaham
    Sounds like the battery to me, weak batteries tend to fail in the winter due to the colder weather.
    Jan 2012
    Midlands
    Another Quick Update,
    Ran the car on the old battery for around 10 miles, and all of the faults have cleared...
    Will be fitting a new battery later, amazing that a battery can create so many problems... and the local vauxhall dealership wanted it in for reprogramming etc...
  1. MOT drama
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2012, 17:42
  2. Click to add drama
    By ScotsDragon in forum The 'Off Topic' room
    Last Post: 13th April 2012, 16:22
  3. Im going to view a Vectra 2.2 SRI! any major faults to look for?
    By David P in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 19:10
  4. My latest drama.. the air con
    By jongiddings in forum Engine & Drivetrain
    Last Post: 7th March 2011, 09:30
  5. Vectra Major Service check list?
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 16:52
