hi guys. there apears to be water appearing in the passengers footwell. has anyone got any ideas what this could be? thanks
have u cleaned out the tray under the wipers?
Do a search for scuttle drain and put your reading glasses on.
It's coming in via the pollen filter, clean the drains out before you need a new heater.
heater matrix leaking??
As said - drain in the scuttle tray blocked and the water comes in through the blower motor!
this can cause the thermal fuse to blow - and also the blower motor to squeel!!..
scuttle tray that's it lol could not think wit it was called there
brilliant thanks guys. i better check that out before it does more damaga. if i get any problems i will drop you a pm big sig. thanks!!
My GSi and Signum did this. The worst part was trying to get the water out of the carpet before it started to smell!
