Thread: Oil light brown colour Corsa D
    Tayside
    Default Oil light brown colour Corsa D
    Hi,
    I'm looking for a bit of advice on my wife's Corsa D 1.4. I went out to give the car a quick check and noticed that the oil underneath the oil cap and also on the dip stick was a light brown colour. There was quite a lot of it.
    I have read about water getting into the oil causing this. The car seems to be driving fine with no problems at all. Is this something to worry about? The car is an 08 plate and has only done 26k miles and is used for short runs which is probably not helping.
    Thanks.
    Dec 2011
    Seaham
    Sounds like condensation building up in the oil. As the engine never really gets hot, it doesnt evaporate away the condensation.
    Take it for a good long hard drive, get the engine nice and hot, it should clear it away.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Quote Originally Posted by Ben50n View Post
    Full Member Big Sig's Avatar
    Also I would change the oil more often as the water in there will damage the engine as the oil isn't as good as it should be like that.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    And as no-one has mentioned it so far... check that the temperature is coming up to 'normal' at a sensible rate.... if the thermostat has died in the default open position, then engine will pretty much always run cool, thus not helping the 'oil cap mayo' situation.
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    not sayin these lads are wrong but in my experiance (twice) when ive had water in oil it was head gasket problem. started off with coffee colour from coolant leaking into oil. then a few weeks later the compression from cylinder was leaking into coolant, pressure was building up and blowing all the water out of reservior.
    Dec 2011
    Seaham
    With head gasket problems, you would also lose water as it either goes into the engine or would be pressurizing the cooling system and blowing it out. You could also get oil contamination into the colling water.
    I would still gamble on condensation only, clean the cap and dip stick and then give it a good run.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Jimbo does have a point.... but I think we're all banking on the hope that the coolant level isn't going down and when the OP takes the cap off the expansion tank it doesn't stink of exhaust.
    Jan 2012
    southwest
    thought id mention it before he went screamin down the motorway tryin to burn away water out the oil. cos if it was head gasket that wouldnt do it much good!!!
  1. Colour code fog light grilles
    By conman in forum Styling
    Last Post: 13th February 2013, 12:42
  2. light brown roller blind new
    By paul.sessions in forum General items for sale
    Last Post: 28th October 2010, 20:47
  3. Airbag light reset? - Corsa D
    By mucklestone in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2009, 12:29
  4. Internal Light colour Changes
    By rickyroo in forum Styling
    Last Post: 10th March 2008, 00:19
  5. Brake Light Cable colour ???
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2006, 02:08
corsa oil brown
why is there brown water in coolant tank corsa d
oil in water corsa d
brown corsa d
