Thread: code reader issues
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default code reader issues
    code reader says there's no connection at all...
    im sure i read that it could be a blown fuse on the passenger side of the dssh but im unsure
    any ideas?
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Anyone?
    West
    What year is your motor & what code reader are you using... the reason i ask is that some obd2 readers only read diesels from 2004 onwards, therefore an obd1 might be needed.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The only code readers that would work on my old Dti were Opcom and Tech 2
    It's annoying as the pedal trick doesn't work on them either
    Dec 2011
    manchester
    what pedal trick
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by killa_uk View Post
    what pedal trick
    This one http://vectra-c.com/forum/showthread.php?t=81742
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    It's a 53 2.2dti and it's opcom that deffo used to work before it was parked up. I'm 99% sure I read that if a certain fuse had gone, then nothing can be read but I can't find the post on here
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    the answer i was looking for was...... fuse 11 7.5 amp on the passenger side fuse panel..
    if this blows, you cant use the obd port.
    thanks al..
    yw mate.
  1. code reader
    By Guss in forum Engine & Drivetrain
    Last Post: 15th March 2012, 08:24
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. code reader
    By billt in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 18:13
  4. ELM 327 - Code Reader
    By coxstevuk1973 in forum Engine & Drivetrain
    Last Post: 11th February 2010, 22:21
  5. Elm 327 Code Reader, Anyone!!!!!
    By whatthevecisup in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 16:36
