Thread: boost leak test
    Jul 2011
    retford
    Default boost leak test
    anyone ever done one on a cdti......
    cheers
    Jul 2011
    retford
    cant findmuch info on this tbh.... done leak tests on 1.8turbo leons and such like, just never on a derv
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    yeah, i did it on Nutrons cdti a week or so back and found his leak for him..
    Jul 2011
    retford
    soooooo, how did you go about it mate. i have a leak tester to connect to inlet pipe after maf. on petrols i disconnected the pcv and blocked.
    cheers nige
    Jul 2011
    retford
    anyone else done one or got a mini guide please......
    Jun 2009
    South Coast
    i have a boost tester i made myself.. its basically a 90 degree silicon pipe elbow that is blocked off on one end with a plastic blank i bought from a swimming pool supply shop nearby. I drilled a hole in the blank and bolted in car tyre type valve that i brought from ebay, I secured the blank in the pipe with a jubilee clip. The other end has a jubilee around it and i fit this around the turbo intake and clamped it up.. I then get a motorised tyre inflater/pump that i run out of the ciggy lighter socket and pump up the boost system of the engine etc. I leave it running and it gets to about 1 bar and holds (with the pump on), i then spray from a gardening squirty type bottle some soapy water around the connections, taking car not drench the engine or electrics, doing one area at a time..
    On Nutron's cdti, we disconnected the pipe from the airbox to the turbo and we attached my boost tester via some silcone and stainless pipe extentions to his turbo's compressor inlet and pumped it up, we found his leak in under a minute. We made some gaskets and fitted them, we then retested and no further leaks were found. He then cleared his error codes and as far as i know we cured his issue, quickly and for free.
    hope that helps..
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Nice info, Caveman.
    I used a Wet & Dry vacuum cleaner, connected to the dose just after the turbo on a 2.0DTi.
    Wickes do one with a blower outlet for about £35.
    Only problem was the noise of the vacuum itself, because I was listening for escaping air, but it was still a lot quiter and safer than having the car engine running during the check.
    Jul 2011
    retford
    so do you not need to disconnect and block anything......just connect compressor to turbo inlet after maf and pressurise?
    Jun 2009
    South Coast
    Yup, its as easy as that
    Sent from my batphone using Crapatalk
    Engine : 1.9 CDTi
    Bit extreme for a DIY'er but we use this where I work and its great:
  1. What are the symptoms of a boost leak?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2013, 21:55
  2. Boost leak test using spare tyre?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 12:08
  3. V6 CDTi Y30DT Leak Off Test/Replacement
    By smitd004 in forum Engine & Drivetrain
    Last Post: 26th August 2011, 04:59
  4. Diesel Leak-Off Test vs Diagnostic Software
    By snapsnap in forum Engine & Drivetrain
    Last Post: 10th October 2010, 20:04
  5. Replies: 1
    Last Post: 15th February 2010, 19:58
cdti boost leak tester
