Results 1 to 10 of 28
Thread: 2.2 direct
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default 2.2 direct
    is it normal to have a bit of crud for lack of a better word, under the oil filler cap, the water bottle is fine, read somewhere that it is normal to have this condinsation etc, but i cleaned the cap yesterday and today i see some, seems to be running ok, its due a oil change, temp sits about 88-90 should i be worried. 2.2 sri direct
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Was it a little creamy mate if so yes it's ok as I bet u are doin lots of short runs
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    yep short runs, i have only bought the car, plus i see one of the wheels bolts has sheared of, do i have to drill the bolt out, in the meantime is it save to drive with 4 wheel bolts.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    It's Dine the little cream mate don't worrie about that also I have drove with 4 wheel nuts for ages but wouldn't reccomend it they have 5 for a reason is the any chance u can take the wheel off and remove the rest of the snapped bolt or has the thread bin stripped
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    its sheared of level i cant get any grip on it, i have heard you can get a stud extractor, drill a pilot hole then use the extractor, is this right.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    my 2.2 is the same, lots of short journeys, fitted a oil catch tank because of the amount of crud comming out of the rocker box breather and going down into the throttle body, did not take long to fill with water and slime.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by decks View Post
    Yes mate, its a tapered thread that goes the oposite way, as you screw it in anti clockwise it eventually locks and the stud should then start to come out. Get plenty of WD40 in the first, a bit of heat around the stud should help as well.
    LINKY
    Dec 2011
    Midlands
    Quote Originally Posted by skidmark1 View Post
    Any details on the catch tank? I have cleaned throttle body on mine which was really gunned up and car running much smoother and picks up cleaner but sure it will return and fancy avoiding too much crap in the inlet manifold.
    Steve
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Stevie76 View Post
    Steve
    Blank the EGR, that will sort your TB problem and look after your swirl flaps.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Is there a how to on that steve I no there is a special blank of plate fit z22yh to allow the water to still flow as the egr is liquid cooled can u confirm that matey
  1. I think my 2.2 direct has too much oil in it....
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 15:18
  2. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
  3. 2.2 Direct mpg normally this bad?
    By Marc C in forum Engine & Drivetrain
    Last Post: 9th August 2008, 12:46
  4. 2.2 Direct 16v
    By cdms811 in forum Petrol Engine related
    Last Post: 12th December 2007, 00:55
  5. 2.2 Direct
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 20:50
does my 05 vectra c 2.2sri direct have swirl flaps on thr engine
