Results 1 to 10 of 13
Thread: Suspension
    Aug 2011
    CO WATERFORD
    Default Suspension
    Hi there, hope some one out there can shed some light on my problem. I recently had the passenger anti roll bar link changed, ARB bushes confirmed as ok, shocks within limits, tested on machine. The problem is, when I am driving behind a high sided vehicle the car is uncomfortable to drive, feeling "wobbly", yet no steering vibration. The garage confirmed that the drivers ARB link was a little worn but no so much as needing replacement.
    The car is a 2005 vectra c, life branded as Opel here.
    Dec 2011
    Seaham
    Think you are driving too close to the vehicle and suffering from the turbulence in the air.
    Dec 2011
    Seaham
    Also, depending on the road surface, if its regularly used by HGV's, you can get "tram lines" in the road, your car will sometimes follow the tram lines in the road.
    Aug 2011
    CO WATERFORD
    Thanks for that, agreed about the turbulence, but I think am far enough behind, never used to be a problem that's why it seems so strange.
    South east
    It could be worn bushes in the upper control arms (banana bars) on the rear suspension, which is a very common failure on the Vec-Cs. It's often the cause of lateral instability issues.
    Aug 2011
    CO WATERFORD
    Thanks for that, I had one done on the passenger side, but dont know if the garage checked the passenger side, without taking off the wheel, can I do anything to check for this. Thanks again.
    South east
    With the car still on the ground, hold the top of the tyre and push/pull it, there shouldn't be any movement.
    Aug 2011
    CO WATERFORD
    Great, will do later.
    Aug 2011
    CO WATERFORD
    All checked and no movement, which is great, shocks never changed and now 120,000km on clock, might be worth considering?
    Dec 2011
    Seaham
    It is harder to check if the shockers are done, unless you can physically feel that there is no dampening when you pull and push it in and out.
    As your car has done a few miles, it would no doubt benefit from new shockers.
  1. suspension
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:40
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. suspension!!
    By leonvectrac in forum Handling & Braking
    Last Post: 11th September 2008, 23:20
