Thread: drive belt tensioner
    Regular Member coooky's Avatar
    May 2011
    washington
    Default drive belt tensioner
    there is an awful noise coming from the side of the engine on my 1.9 cdti where the cam belt is,i thought it was the water pump at first but had that and a new cambelt kit fitted, but after reading a few posts i have come across a few that say it could be the drive belt tensioner the garage said it needed a new fan belt is the drive belt the same as a fan belt ?? also is this the correct part second one down
    http://www.eurocarparts.com/tensione...rs-and-dampers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Your garage needs to learn some simple terms. A fan belt drives the cooling fan of a car, most cars (including the Vec C/Signum) have electric cooling fans fitted nowadays.
    The belt they are referring to is the Auxilliary or drive belt.
    Can't see the tensioner you've linked though sorry, what is the part number they give?
    May 2011
    washington
    i thought most cars were electric fans now also
    Part No.: 326510340
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    Hi I have this on my 1.9 cdti it was lay pully this is not needed I removed and put a smaller belt on it it is now fine the newer 1.9 did not have this pully part no is v0093190605 from vauxhalls you remove it my son is a vauxhall tec all is well now
    Aug 2009
    portland
    The part number is for the belt .
    Aug 2009
    portland
    The pulley is the one between bottom fly wheel and air con it made a winning noise when you rev the engine £14 the belt cost
  1. Drive belt, pulleys and tensioner replacement
    By no1vic in forum Engine & Drivetrain
    Last Post: 13th November 2016, 20:41
  2. drive belt tensioner
    By coooky in forum Engine & Drivetrain
    Last Post: 11th April 2012, 18:19
  3. Aux Belt Tensioner Help !!
    By keithtinman in forum Engine & Drivetrain
    Last Post: 25th July 2011, 21:57
  4. Aux/Drive belt tensioner & pulley replacement
    By Marky in forum Engine & Drivetrain
    Last Post: 5th October 2010, 20:43
