Results 1 to 3 of 3
Thread: Signum started then stopped
    Regular Member portreathbeach's Avatar
    Jan 2012
    Cornwall
    Default Signum started then stopped
    I have a 2004 Signum 2.0 and started it this evening. It ran for 30 seconds and then stopped, I don't remember seeing the EML illuminated. It then took a minute to start again, but seemed OK. I used a diagnostic tool and error codes P1222 (traction control) and P0500 (speed sensor) were pending...this may be from a while ago...maybe.
    Anyway, I lifted of the plastic engine cover to see if I could spot anything and discovered a small white pipe with a hole in it and a pipe fitting (down between the engine and battery) with 1 pipe connected and the other connection with nothing....
    Notice the hole in the white pipe in the center of the screen. What is this pipe, and what does it do?
    Notice the black pipe fitting just to the right of the center, should there be something connected to this?
    Thanks for any help.
    South east
    I take it from the pictures of your engine that you have the diesel 2.0? Some people might mistake your description of "Signum 2.0" as being the petrol engine.
    Jan 2012
    Cornwall
    Yes. It is the 2.0 DTi engine.
    I understand the white pipe is a vacuum pipe, but I still cannot work out what is meant to be connected to the black connector (pic 2)
  1. Stopped by police @ 2am
    By Johnsdutton in forum Comedy & Humour
    Last Post: 31st December 2012, 17:43
  2. Fan stopped working
    By andyxedos in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 23:18
  3. Powersteering has stopped??
    By kiwiboy in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2009, 21:27
  4. Air Con stopped working
    By pvmoore in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2009, 22:31
  5. Stopped for Speeding!
    By Dodger in forum Comedy & Humour
    Last Post: 6th February 2008, 19:15
