Results 1 to 10 of 11
Thread: Vectra C Preface Z22SE Drop Links and ARB Bushes
    Regular Member nick-v2.2's Avatar
    Nottingham
    Default Vectra C Preface Z22SE Drop Links and ARB Bushes
    Evening,
    Hoping to replace the existing parts with better quality parts as they have lasted around 6 months.
    Seen the uprated drop links posted on ebay
    (http://www.ebay.co.uk/itm/Saab-9-3SS...0#ht_914wt_952)
    and thought i might try them.
    Can anyone confirm these are the correct part number for Vec c Preface z22se.
    Also the arb bushes, is there any easy way to identify which ones i need for the front, i know its either 24.2 or 25.2. I thought one has little bobble's on one side? expect to be wrong though. I dont know if it matters or changes things, but I have gone from standard shocks/springs to 30mm drop.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    All the drop links are the same mate so you'll be fine with them.
    Nottingham
    cheers rushy, that's them ordered tomorrow, just need to identify these arb bush's.
    Hoping to get poly's for the front.
    South east
    You'll have to read the part number on the side of the existing ARB bush to identify it.
    Vehicle : SRi
    Mileage : 137000
    These are the ones the dealer gave me for my prefacelift 2.2 SRi.
    Although there have been posts in the past where the same cars have had different ones fitted to each other. Think VX must just raid the parts bin when they made the Vec c.
    Sent from my Sony Ericsson Xperia using Tapatalk
    South east
    They're for the 24mm ARB.
    Nottingham
    my car is not an sri its an elegance 2.2.
    I have had a friend measure the bar from the visible part when steering in full lock and he says its the 25.2. I thought this one was mainly on the sri's and lowered standard cars.
    South east
    I think you'd struggle to get an accurate measurement of the ARB itself, because the difference between the two sizes is only 1mm, and also because the diameter of the bar will vary where it's worn or near a bend. If you've gone to the trouble of taking the wheel off to measure the ARB, instead shine a torch onto the bush and read the part number on the side of it.
    Nottingham
    i have not removed the wheel, just put it in full lock.
    It was also measured with a proper caliper tool.
    We jacked the car up and tried to check the arb number, but it is on the inner side. We tried with a mirror but couldn't get all the numbers. so didnt bother
    swansea
    Easier still, phone a dealer with your reg no. and ask for the part no.
  1. Replies: 5
    Last Post: 21st March 2010, 12:34
  2. arb bushes ans drop links
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 17:01
  3. Drop Links and bushes
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 09:44
  4. Bushes and drop links?
    By GaryJ in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2007, 18:35
vectra c drop link replacement
vectra c 2.2 sri drop link
