Results 1 to 10 of 11
Thread: non return valve
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default non return valve
    Due to my on going cold start problems i am thinking of having a non return valve fitted.Could some one tell me what diameter i would need on the valve and does it be installed in line after the fuel filter?thanks
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Make it a hand pump with a non-return valve. Kills potentially 2 birds wth one stone
    Easier pump priming, and no drainback
    Nov 2011
    Something like this...http://www.ebay.co.uk/itm/HAND-PRIME...item1c2240480c
    However, i'm not sure about the hose size. Hopefully someone else here may be able to help with that
    Derry
    Thanks mr derv for your reply,think of just doing the non return valve on its own 1st tho,dont think the wife would fancy opening the bonnet every morning to prime the diesel!!lol
    Nov 2011
    You wouldn't need to prime it every time, only if it's "ever" run out of fuel Lot easier than waiting for the high pressure pump to draw the fuel through if it's run dry
    Added bonus of it having a non-return valve in it too
    Derry
    Ah right,sori Mr Derv i must have mis-understood you,it might be an idea to fit one of those then,i just thought by the look of your`s that it would have to be primed on a daily basis on the 1st start of the day.
    Nov 2011
    No worries Like i said, potentialy kills 2 birds with one stone
    Regular Member dervb's Avatar
    Jun 2007
    Thornton merseyside
    Hi VH, on my vec o4 dti, its 1/2 inch, that's what the fittings were when I fitted my fuel heaters.
    Derry
    I think i read somewhere thats its 12mm,does this sound ok?
    Jun 2007
    Thornton merseyside
    Indeed I am a imperial man ,do I sound old ,paper for thrupenc 2n6 lol.
  1. 1.9 CDTI Fuel non return valve help
    By 2wheelstu in forum Engine & Drivetrain
    Last Post: 9th April 2012, 08:09
  2. Non Return Valve
    By woteva in forum Engine & Drivetrain
    Last Post: 27th January 2009, 15:47
  3. Return
    By WHOOSH05 in forum General Chat
    Last Post: 16th December 2008, 20:35
  4. On my return
    By alex_c in forum Introduce yourself.
    Last Post: 18th February 2008, 21:04
  5. Have you/Would you return to an old job..
    By BigMan in forum General Chat
    Last Post: 16th January 2008, 23:28
