Results 1 to 10 of 15
Thread: Oil change syphon???
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Oil change syphon???
    For one reason or another, I just cant lay under my car any more to get at the sump bolt, and I heard that there is a syphon available to remove the oil through the filler cap.?
    Has anyone used one?, how effective are they at removing as much oil as possible. I assume that this would only be for people who regularly change oil, not let it turn to sludge...
    gwent
    It's not through the filler cap it goes down into where the dip stick goes so it picks up from the sump you can buy them from demon tweaks starting from £50 up wards
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, down the dipstick.
    I would not recommend them as they don't get all the sludgy stuff from the bottom of the sump out.
    MUCH better to use the drain plug - if you can.
    scotland
    If you're using a full synthetic oil then sludge shouldnt be a big issue, I haven't seen 'lumps' in oil as its draining from a sump for many a year, mostly thanks to the purity of synthetic lubes IMO.
    Oct 2007
    south wales
    wow £50? didnt realise they were that much...
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Agreed Ted, shouldn't be a big issue, but it is preferable to get out as much residue as possible on oil changes. I will never use the suck out method via the dipstick tube.
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I find the best way to drain oil is to remove the sum plug, and then while it is draining so and do something else. Having lunch is about a good time to get all the oil out and along with it any residue. I just leave it draining for ages.
    Jun 2011
    Herts
    I wonder if the pump gets the bit that doesn't drain out when you use the sump plug then??? guess it depends on the shape of the bottom of the sump........
    might buy me one of these as it'd save having to jack up the beast to get at the engine tray off....... lol
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Quote Originally Posted by ftm100 View Post
    Thats not a bad price!
  1. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  2. Astra fuel syphon
    By carvaletingpro in forum General Motoring Chat
    Last Post: 20th November 2011, 11:59
  3. Syphon fuel ?
    By si_sri in forum Engine & Drivetrain
    Last Post: 17th January 2011, 12:19
  4. syphon
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 10:32
  5. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
oil change using syphon forum
