Thread: Wiper arm question
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    confused Wiper arm question
    Near side wiper started tapping the trim at the bottom of the screen,so thought take it off and move it round a spline and put it back, found no splines in the arm and the ones on the shaft full of crap cleaned them out bought a new arm,no splines in the new arm either stealer said its the right arm so fitted it and tightened as tight as poss.Never come across this before now thinking i wasted time and money,do the splines on the shaft cut thier way into the sleeve on the arm when the nut is tightened,cheers for any answers.
    Jun 2011
    Vehicle : vectra
    Year : .....
    yep deffinitely wasting my time
    Quote Originally Posted by patch22 View Post
    Calm down dear boy
    The splines are on the bit the wiper arm bolts too so have probably worn away is someone in the past has let it slip. Just reposition it and do it back up, it doesn't really need splines as it tightens down onto the "cone".
    Jun 2011
    Vehicle : vectra
    Year : .....
    Thumbs up
    cheers sig thats cleared that up thanks very much
    Dec 2011
    Seaham
    If it doesnt bite down on the splines, then try using a piece of tin foil wrapped around the splines, this often gives that little bit of extra thickness to help grip the wiper arm.
    Engine : 1.9 CDTi
    Mine does it too.
    Turns out the owner before me did the cable tie trick due to worn ball joints.
    Can you move your wiper quite a bit?
    Jun 2011
    Vehicle : vectra
    Year : .....
    no not much nothing excessive anyway now the arm has been repositioned seems ok its just every other set up i've come across theres been splines on both shaft and arm
    exeter
    where and how much did you get your new wiper arms for ? just asking as i think mine are bent .there is a big gap between the piler and the wiper blade at the top when it comes up and touching the piler at the bottom when the arm comes up
  1. Wiper arm question
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 13:12
  2. Quick wiper arm question?
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2011, 17:30
  3. Flat wiper question
    By sri_joe in forum Styling
    Last Post: 27th June 2009, 07:03
  4. Another wiper question
    By mad mechanic in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2008, 17:29
  5. A Quick Wiper Question
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2007, 14:21
