Thread: Mod Virgin ....
    Regular Member Gazza90000's Avatar
    Newcastle upon Toon
    Default Mod Virgin ....
    Just bought Door Pins , Valve Caps and a Richbrook antenna from LMF..
    The Door pins look good the Valve Caps look good but the RICHBROOK antenna don't fit the screw in bit on my car.
    Its it a different ariel for DAB ?
    No doubt my next thread will be in the For Sale section.
    Jul 2006
    No idea about the antenna, but just be careful with those valve caps. I remember reading a thread a little while back where a whole string of people had to cut the metal caps off..
    There is a proper name for what happens, but basically after a while, the metal of the valve and the metal of the cap fuse and become one.
    I suppose if you took them off once a week to check your pressures, it wouldn't be a problem!
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    Just apply some copper grease to the inside of the valve cap matey, works a treat......
    Newcastle upon Toon
    Exclamation
    Yikes Will get straight on it....
    Any clues on the ariel..
  1. sky or virgin
    By Angel1368 in forum The 'Off Topic' room
    Last Post: 12th January 2013, 17:41
  2. Sky F1 Channel on Virgin
    By sol in forum The 'Off Topic' room
    Last Post: 7th March 2012, 11:43
  3. Virgin
    By Thomo206 in forum Introduce yourself.
    Last Post: 10th November 2009, 10:50
  4. forum virgin
    By yoz1974 in forum Introduce yourself.
    Last Post: 22nd April 2009, 01:17
  5. Virgin or Sky
    By yorkshireborn in forum General Chat
    Last Post: 8th March 2008, 13:22
